Old 05-07-2021, 03:16 AM
saqibhassan saqibhassan is offline
Default Resolution bug 2021.3
Hi.
HP monitor 2160p - works perfectly on Catalina.
On Big Sur meters and graphics get very laggy.
if I set resolution to 1080m, all is good !!
if I adjust protools edit-window (around 1080) all is good !!
This reflects meters, and plugins like analyzers etc.
I have a dupicate setup (same machine - different startup drive) with Catalina.
It all works perfecly in Catalina (latest)
Mac Mini 2018
16 GB Ram
Latest Big Sur
20221.3 Ultimate
Best
Saqib
Old 05-07-2021, 06:00 AM
Default Re: Resolution bug 2021.3
hmm, im seeing the same problem in cubase 11 pro, that is also working perfectly in Catalina !
Old 05-07-2021, 01:45 PM
I haven't seen this, but based on your description, it seems like Catalina to Big Sur is the independent variable (or was it the dependent variable? I always get those mixed up). Nevertheless, the change in the OS seems to be the cause of the your resolution issue.
Obsidian Dragon
Mac Studio M1Max - 64GB
PT 2021.3 on macOS 11.3 DerrickC Pro Tools 3 04-27-2021 06:39 PM
2021.3.1 innesireinar Pro Tools 80 04-22-2021 01:31 PM
Pro Tools First 2021.3 is out Netmania Pro Tools | Intro Discussion 2 04-02-2021 01:26 PM
