Old 10-07-2015, 02:37 AM
dbuaudio dbuaudio is offline
Default PT11 Apollo slave not seen
Hi all, I'm running PT11 with two Apollo quads as master / slave. The master Apollo passes audio to PT fine, but any input to the slave does not show in PT at all. Apollos are linked fine, PT shows all the Apollo patch options it should, but no signal. IO setup in PT agrees with the core audio layout in Console Settings. Any clues? Thanks for help
Old 10-09-2015, 02:21 PM
ryanstewartguitar ryanstewartguitar is offline
Default Re: PT11 Apollo slave not seen
Are you using 32-channel PT Mode for inputs and outputs in Console's Core Audio settings?
- Ryan Stewart
www.ryanstewartguitar.com
Old 10-12-2015, 03:02 AM
Doh.. thank you Ryan. Found PT 32 mode for the outputs, repatched then lost the plot...
Mac 0/s 10.9.2, 2 Apollo quad, PT11
Old 10-12-2015, 10:37 PM
Woohew! The flexible core audio routing with the Apollo is sweet. Let's us give a nice middle finger to Avid's completely BS policy of restricting the IO to 32 channels for no reason whatsoever. Ain't no room for crap like that in today's world.
- Ryan Stewart
Using Outboard with PT11 and UAD Apollo Console 2 Monk Pro Tools 11 11 04-03-2015 06:24 AM
Marbles well and truly scrambled... PT11 with UAD apollo stephen duffy Pro Tools 11 2 01-18-2015 05:34 AM
Digi 003r slave to Apollo twin? Rayray2000 Third Party Interfaces 2 10-09-2014 07:20 AM
PT11 compatible UA Apollo interface? djkikis macOS 4 07-05-2013 07:44 PM
Symphony couldn't do it-Could Apollo/PT11? Barry Johns Pro Tools 11 26 05-03-2013 04:28 PM
