Old 07-21-2022, 05:26 AM
ewanp ewanp is offline
Default HDX issues moving from Mac Pro 6,1 to M1 MacBook Pro?
hey there,
any busy pros here successfully made the transition from a 6,1 Mac Pro to a 2021 M1 MacBook Pro?
I am currently mulling whether to try running my full rig from a laptop in clamshell mode - would be connecting a McDSP APB16, UAD Satellite Thunderbolt Octo, a Thunderbay 4 HD bay and an HDX card in an Avid Thunderbolt enclosure, via a CalDigit dock. Plus internet and a Trinnov connected via Ethernet.
Despite having given me good service, my 8-core trashcan is struggling a bit with larger sessions at higher sample rates, despite the increase in efficiency that the Hybrid Engine gave us last year.
Anyone made a similar transition and have any experiences to share? My other option is to buy my last ever Intel Mac in the form of a 16 core Mac Pro which I know will just work and should be supported for 4 years or so, but the temptation of getting nearly the same performance + mobility for half the price is strong!
Any thoughts?
very best,
Ewan
MacPro 6,1 8 core, 64gig, Pro Tools 2022.6, HDX via Avid Thunderbolt Chassis, Orion 32HD
Ewan Pearson
Production, Mixing, Remixing
www.ewanpearson.com
Old 07-21-2022, 11:38 AM
protoolsuserman protoolsuserman is offline
Default Re: HDX issues moving from Mac Pro 6,1 to M1 MacBook Pro?
Hi Ewan,
You'd be wise to first stick a free app called Macs fan control on your Mac pro and set fans to 1500rpm.
It will keep everything running much cooler and so your machine will run better.
Could save you ££££
Old 07-22-2022, 05:58 AM
dominicperry dominicperry is online now
Originally Posted by ewanp View Post
hey there,
Any thoughts?
very best,
Ewan
Ewan Pearson
www.ewanpearson.com
I can't answer your question directly, I'm not an HDX user, nor do I run a commercial studio. But I do have both the machines in question (Mac Pro 7.1 16-core and MBP M1 Max) and can tell you two things.
Firstly, for practical purposes, the processing power is about the same. Some variability in performance across different applications, but they benchmark very similarly and the real-world performance seems to reflect this.
Secondly, if I was running a commercial studio, I'd definitely keep the 7.1. As well as much better proven reliability with external devices (and you have plenty of those), I've kept it on Catalina for the specific ability to be able to easily clone the boot drive (to an external drive) and then boot from the external without fuss. The value of being back up and running in 5-10 mins in the even of a boot drive failure is very valuable in general.
I guess the only other point is that the MBP uses about 6 watts at idle and 20-30 if you push it, whereas the 7.1 uses 90w minimum and 150+ under pressure, so the electricity costs are significant (about £250 p.a. vs £25) but that's a business cost if you're running a studio.
You should be able to pick up a 7.1 now at about 40-50% discount. When I've tried to sell mine I've found very little interest (as well as the usual eBay misery). It will keep working until it doesn't.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 07-24-2022, 03:39 AM
I agree with you completely Dominic!
Yes eBay is a misery, do avoid where you can. Good for buying but not for selling I'm afraid.
Keep your 7,1 machines they're absolutely brilliant and pro for a reason!
Old 08-01-2022, 04:22 AM
thanks so much for the feedback, Dominic. Wallet is pushing me in the direction of the laptop but I actually want the tower and to not have to think about compatibility at all.... It is my living and I'm busy, thankfully. Maybe looking for a used one is the way to go.
very best,
Ewan
Old 08-01-2022, 05:00 AM
Southsidemusic's Avatar
The OP has a Trashcan 6.1 and not a 7.1 which is a HUGE difference
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 08-01-2022, 05:08 AM
Will Russell's Avatar
Will Russell Will Russell is offline
I made a similar jump from a 5,1 cheese grater MacPro to a 16" M1PRO MacBook Pro. The MacBook Pro is an improvement in pretty much every way that I could measure. I can handle larger sessions more smoothly, less stress on the CPU and this is all running Rosetta 2!
I ultimately replaced the MacBook Pro with a Mac studio because I needed the MacBook Pro for other applications. Super sweet machine, runs beautifully!
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Considering moving from old MPro to Macbook Pro, how will it perform in comparison? BigBadBill Pro Tools HDX & HD Native Systems (Mac) 1 04-21-2016 11:04 AM
Moving from G5 to Macbook Pro i7 using 002, Blue Ridge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-28-2010 06:27 AM
Volume issues moving from Mix Plus to HD brotone Pro Tools TDM Systems (Mac) 2 11-10-2008 12:35 PM
Moving protools le 7(windows)to intel core 2 duo macbook pro oasis8916 Pro Tools TDM Systems (Mac) 2 09-14-2007 04:31 PM
moving protools le 7(windows)to intel core 2 duo macbook pro oasis8916 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-14-2007 11:22 AM
