Adat output louder than analog output ?
Hello,
I have a strange problem and i need some help. I'm using a DIGI003 with SSL XLOGIC ALPHALINK MADI-AX as A/D converter, and recently i discovered that my ADAT OUTPUT are louder than my ANALOG OUTPUT. I'm Protools, I sent 1K Hz/ 0 dBFS with a signal generator to ADAT OUTPUT 1-2[bleep] and then i plugged the OUTPUT of my A/D converter to ANALOG INPUT 7-8 and i don't have the same level, my input level is 3.5 dB more louder. But when i do the same thing with my OUTPUT ANLOG without using the A/D converter, i have the right IN/OUT level. So, i deduced that the problem come from the A/D converter but i don't understand it. Then, i tested another A/D converter and it's also weird, neither, i don't the same IN/OUT level if i use the ADAT OUTPUT, Could the problem be the ADAT OUTPUT of my Digidesign?[bleep] For the record, I'm using always the same cables. I am curious as to any ideas? Has anyone else experienced this? Thanks, Rodrigo |
Re: Adat output louder than analog output ?
Yeah, I have been doing mixdowns on analog mixer using the analog and digital outpts of the 003, and the ADAT outs always have to be turned down on the mixer... Just get used to it...hehe
se.audio |
Your problem comes from the different output sensitivity of the 003 (+18) and the Alpha-Link (+22).
RIGHT louder than LEFT output!!!HELP!! [SOLVED] | MallahStudio | macOS | 5 | 11-26-2013 05:17 PM |
Analog Output louder on Channel 2 (Right) (002) | krofa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-11-2007 04:26 AM |
002 Rack Louder Right Output, Please HELP | clod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 09-29-2004 12:54 AM |
Using AES output without sending to Analog or Adat | limgim | Tips & Tricks | 0 | 01-15-2004 08:45 PM |
louder output in mp3 option | Joseph Anderson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-15-2002 02:46 PM |
