Protools INSTANTLY crashes when importing (USB midi issue?)
This problem is KILLING me right now! I can't get any work done.
Basically this problem only happens while using my outboard synth (usb) and playing back midi notes sequenced in LE (is that what you call a "slave"?). Everything seems to work great till I pause the session and try to import audio files. That's when it crashes and disappears without a trace (no error message, just boom, gone). It seems to happen the instant I click on an audio file. Also, I tried to open "workspace" and it crashed instantly as well. I've been searching digidesign.com (and google etc...) but I can't find any information at all. Again this ONLY happens while using my outboard synth. I was using a midiman usb connect then I just plugged my synth (Korg r3) directly in (usb) and it still happened. It should be noted that I had this problem with my other synth too, so that's not the issue as far as I know. Maybe it's a bad driver? You're help would be MUCH appreciated! I'm running... Protools 7.4 Windows XP M-Box 1 Pentium 4 CPU 2.80Ghz 1 GB Ram |
Re: Protools INSTANTLY crashes when importing (USB midi issue?)
So I just called Digidesign Tech "Support" but I'll have to pay 3 dollars a minute to get any help!?!?!?!? Because my product is older than 90 days, that is some [bleep] right there.
I didn't realized the customer service was so horrible. So I have to pay to correct a problem with there product? That is really backwards to me. Basically I'm screwed here. My last hope is to get help from you fine people. |
This is the Mac forum. Try posting in the PC forum.
Pro Tools 11 Crashes instantly on Startup. PT 10 is fine. | jkess | macOS | 5 | 02-05-2014 12:42 PM |
New cs1 patch on 8.0.3 on SL crashes instantly | guym | Pro Tools M-Powered (Mac) | 27 | 04-17-2010 08:55 PM |
Importing AAF crashes Protools | 24bit dither | Pro Tools TDM Systems (Mac) | 1 | 07-04-2009 02:41 PM |
PT crashes INSTANTLY when importing (USB midi issue?) | Pony Slaystation | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-25-2007 06:52 PM |
Protools Crashes when Importing Audio?? | brinaddison | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 05-30-2005 02:04 PM |
