Behringer ADA8000 getting ADAT \"Pops\"
Just loaded a new ADA8000 into my rack.
Have it set to master at 44.1. goes out optical to 002r (also set to 44.1) Enabled a ADAT input to record on PT Mixer screen pluged in a bass get decent sound...levels fine but also getting "snap-crackle and pops" Unpluged bass from ADA8000 and they are still there. Just random pops and such. any help? peace
Digi 003R * PTLE 8.0 +AMD Dual Core * 4GB Ram and a dream.................... My Studio http://www.bleedstreetstudio.com |
Re: Behringer ADA8000 getting ADAT \"Pops\"
You need to set Pro Tools to clock to the ADA8000
Setups->Hardware->Clock Source
Don't use Behringer products?
Seriously, tho, definately sounds like a clocking issue. Do you have both of the ADAT cables hooked up? One coming out of the DIGI, into the ADA, and one coming out of the ADA into the DIGI? The loop might be necessary for proper clock function... |
Thanks
Here is what it is set to now Digital input RCA=S/PDIF, OPTICAL +ADAT is checked. OPTICAL is not? should it be since I am using optical? Clock source is set to INTERNAL can choose from ADAT S/PDIF Optical/S/PDIF
Clock source should be ADAT.
Don't mess with the other setting, it is correct.
THANKS,
So far so good
Why woulndt he want the ADA8000 to slave off of the Digi002r?
-AIM: RS Recordings -Skype: RSRecords | Pro Tools 8 Native | Windows 7 64-bit| Q6600 @ 3.0ghz | 8GBs RAM | Digi002r | Studio Site: Red Sneaker Records |
That may work, but it is standard practice to sync to the external piece. I doubt its true of the Behringer, but most external pre's have a clock that is likely better than the internal one. You SHOULD only need a single lightpipe for sync(my rig works fine clocked to an ISA428).
i am having a similar issue, but instead of the constant clicking that i get when it's clocked to the digi, i get just random pops every 20 seconds. could this be dust near the lightpipe or what? should i clean it out inside. the sound is almost like when the pots aren't clean on my mixer and i move them around. ideas?
Mac Pro w/ Lion. PTLE 8.0.5. |
I did clock it correctly, but getting pops anyway. Changing the lightpipe cable solved the issue.
HDX-1 MacPro5,1 Raven MTi2, PT12.7 |
Behringer ADA8000 (BLA) | JONK | Pro Tools 9 | 14 | 03-14-2012 02:28 PM |
Behringer ADA8000? | sethbrand | General Discussion | 3 | 02-20-2007 11:58 PM |
Behringer ADA8000 | kevinsimons | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-18-2006 12:06 AM |
Behringer ADA8000 pops and clicks | patrickhayes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-02-2005 07:53 AM |
Behringer ada8000 | hotstuff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-21-2003 07:01 PM |
