  #21
Old 06-25-2021, 08:00 AM
tripmusic tripmusic is offline
Default Re: Color patette customization complete failure
I figured out a partial workaround... Copy any random .ptpreset file to the Color Palette folder and name the file whatever you plan on saving it as. Then after making any tweaks to the UI, in the Color Palette dialog box, save-as and replace that file. The quick presets still don't work, but you can still recall your settings by using the dropdown menu.
  #22
Old 06-25-2021, 08:11 AM
It seems a permanent fix has been found.
https://www.pro-tools-expert.com/hom...-we-have-a-fix
Scott Gatteño
  #23
Old 06-25-2021, 10:12 AM
BScout BScout is offline
It is a folder permission issue.
the Quick Presets should form entries like so:
You can create the files so they can be written over from within Pro Tools if there's a problem.
  #24
Old 06-25-2021, 11:08 AM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Can't save UI Customization settings..
Check the Permissions for the Pro Tools Presets folder in /Users/*username*/Documents/Pro Tools/ ...mine's set to Read & Write for my account, and save/presets are working.
linkedin
Last edited by jeffro; 06-25-2021 at 11:11 AM. Reason: Merged similar threads after replying.
  #25
Old 06-25-2021, 11:14 AM
Cheesehead Cheesehead is offline
Just delete the 'Color Palette' folder in Documents/Pro Tools and make a new folder in the same place. Label it Color Palette and your preferences will be fixed & saving will work.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
  #26
Old 06-25-2021, 11:17 AM
Ah, I see that's what PT Expert suggest too further up the thread....
  #27
Old 06-25-2021, 12:24 PM
TimNielsen TimNielsen is offline
Default Re: Can't save UI Customizations or Presets in 2021.6
This will fix it.
  #28
Old 06-25-2021, 12:29 PM
Yes I've since changed the folder permissions. My fix was just what I came up with last night.
  #29
Old 06-25-2021, 01:44 PM
Default Re: Pro Tools 2021.6
Originally Posted by MixerGuy View Post
Protools color palette issues. How to fix.
I don't know why they didn't just change the permissions on the original folder. Would have been simpler.
Jack
QAPLA!
  #30
Old 07-02-2021, 09:40 PM
Zak7 Zak7 is offline
Not saving presets in any way, not Save, Save As or even hold+click over the fast 5 preset tabs
Can't save any plug-in presets SomeOtherGuy Pro Tools 2020 5 03-11-2021 09:42 AM
The presets in the workspace window don't save... Arno Peeters Pro Tools 12 4 06-11-2017 08:43 AM
Workspace view presets don't save travistko Post - Surround - Video 10 02-15-2017 06:08 AM
Control 24 customizations Noizetrip ICON & C|24 21 12-09-2011 10:34 AM
Master X3 won't save new presets macaholic Post - Surround - Video 2 01-14-2008 09:53 AM
