Old 09-08-2021, 05:32 AM
Cryos's Avatar
Cryos Cryos is offline
Default Plug-In Flip Mode
Hi there, I'm running a Doc, iPad and Artist Mix. in the past I'd be able to Flip faders on the mix and access "ANY" plugin parameters via faders on the mix surface. Seems that functionality has been removed and I can only access EQ and Compressor parameters..
Eg.. on a given channel let's say I have an "Avid Channel Strip", "FabFilter Q3" and a "CEDAR". I can flip the mix surface to access the channel strip and Q3 but the CEDAR wont flip. I can only access the CEDAR via the DOC.
Am I missing something ? Is there a pref somewhere I need to change or is this a bug? Thanks
Running Protools Ult, 2021.7, Mac Pro late 2013, 64 gigs ram,3.5 GHz 6-Core Intel Xeon E5. Mac OS Mojave 10.14.6. Protools Dock. Artist Mix , iPad Air 2
Cory Rizos, CAS
Re-recording Mixer/Sound Designer
Montreal, Quebec
http://www.imdb.com/name/nm0007185/
coryrizos.com
Old 09-09-2021, 07:25 AM
EddieJones's Avatar
Default Re: Plug-In Flip Mode
Have you checked whether you are in Channel mode when on Cedar?
PC and plug-in flip mode Muzoid ProControl, Control|24, Command|8 3 01-26-2008 06:41 PM
Plugin flip mode Mano Tips & Tricks 1 04-08-2001 08:24 PM
Plugin flip mode Mano Tips & Tricks 3 04-08-2001 08:13 PM
Plug in flip mode Mano ProControl, Control|24, Command|8 2 04-08-2001 02:20 PM
5.1 Flip Mode Backwards Kenny Gioia ProControl, Control|24, Command|8 1 02-24-2001 07:17 PM
