Track Presets [solved]
Trying to setup the track presets (hack) in PT12. Have put the folder in documents/pro tools (Windows 7), have changed it to .ptxt file. When I go to create a new track in PT, I don't see anything in the list except the standard track types. What am I missing?
Re: Track Presets
SOLVED: The actual track presets have to be in subfolders under the "Track Presets" folder. If they are in the root, they don't show up. So, for anyone looking for the quick and dirty steps for this for PT12 (and likely 11 too):
1. Create a Track Presets (plural) folder under Documents / Pro Tools 2. Create your track preset sessions, select the tracks you want to have as part of the preset and Export them as a session to the folder you just created. HOWEVER, you need to put them in logical subfolders like maybe 2Bus, Vox, Cue, etc.....whatever. 3. Once saved, go to explorer or whatever it's called in Mac-land and change the file suffix from .PTX to .PTXT making it a template. 4. Now when you use the new track dialog, you'll see your subfolders listed under the track type drop-down and you can select any of your self-created presets from there. Hope this helps someone. I'm thinking it might belong in tips and tracks session but I'm not sure how to move it. |
Re: Track Presets
This didn't do the trick for me.. Still not showing up in the "create new track"-window.
Win10 Pro x64 Asus x99 Deluxe Intel i7 5930k 3.5 GHz 16 Gb Kingston DDR4 Asus r9270 DC2 4Gb DDR5 Focusrite Scarlett 18i8 ProTools 12.5.1 |
Re: Track Presets
This hack was never stable for us, so we still use import session data for this and that works very well.
my blog:Tamas Dragon |
Re: Track Presets
However, if it works on one pro tools install - it should work on all.. This is just weird, I've google'd it - and no one else seems to have this issue I'm having.
Re: Track Presets
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Re: Track Presets
Really useful video! Thanks for that.
Re: Track Presets
So Now that Pro tools 12.8.3 is out, on their website they are promoting saved track presets with a key command button of (option+Shift+P) or going to track tab and selecting -saved track preset. however, the key command doesnt work for me nor does the option on the track tab appears. I have everything up to date, using a macbook pro-running on PT 12.8.3, if anyone has any tips on getting this resolved that would be great
Re: Track Presets
IIRC, Track Presets are not in 12.8.3, but in 2018.1.0.
Re: Track Presets
Correct!!
PT 12 Track Presets | jkeefauver | Tips & Tricks | 43 | 01-24-2018 09:40 PM |
Mono source track made into a stereo Commit track [SOLVED] | albee1952 | Pro Tools 12 | 9 | 09-21-2016 05:30 PM |
Copied track volume level changes after I paste track [solved] | shamanrock | Pro Tools 11 | 1 | 08-03-2015 05:04 AM |
Track Presets!!! | albee1952 | Pro Tools 10 | 8 | 12-29-2012 08:13 PM |
Track presets in PT??? | dgkenney | Pro Tools TDM Systems (Win) | 3 | 12-22-2009 10:03 AM |
