How do you automate the effects parameters?
I know how to automate everything else except the effects parameters....please help.
Thanks
"It is better to be silent and thought a fool than to open one's mouth and remove all doubt." - Mark Twain. |
Re: How do you automate the effects parameters?
You click the plug-in box where it says "auto," then choose which parameters you want to add. Then you should be able to click on the display button for the track and see those parameters. When chosen, parameters are displayed as black lines.
While in the plugin window, you can also just command-control-option click any parameter and it'll show up in the automatable-stuff list (along with track pan, volume, mute automation, etc).
It's not rocket surgery |
Thanks guys!!...
Set Plugin Parameters to automate with C24 | mite | ICON & C|24 | 1 | 02-18-2010 10:11 PM |
Automate effects | mck93 | Tips & Tricks | 1 | 04-25-2006 04:24 AM |
Automate Effects | SamuelAdams | Tips & Tricks | 3 | 06-17-2004 07:13 AM |
Can Oxygen 8 automate plug-in parameters? | aframerecordings | Pro Tools TDM Systems (Mac) | 0 | 12-12-2002 02:03 PM |
How do you Automate Plugin effects? | dcornutt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-22-2001 12:27 AM |
