Old 04-01-2010, 03:40 AM
ungratefuldead ungratefuldead is offline
Default Connecting an ADAT interface to a 192I/O
Hi guys,
yesterday I tried for the first time to connect my Motu 8Pre to the 192I/O using and ADAT connection.
I'm able to get the signal of a Mic in to the Motu but not in PT.
The connection are fin I'm going in Hardaware tab and change the Clock source in ADAT but still nothing.
I tested the two ADAT cable and use two spare ones, also I tried the Motu trough ADAT connection on my LE system and it works perfectly.
The sample rate it's for both 44.1.
There is anything that I need to do or flag in the option in order to use it?
My system:
PT HD 2
192I/O
MAC Pro Quad core
Thanks
Matt
Old 04-01-2010, 04:34 AM
BradLyons BradLyons is offline
Default Re: Connecting an ADAT interface to a 192I/O
Did you properly route everything in the patchbay of ProTools? Which optical in did you use, the one on the digital card or the one that without the SRC capability?
Thank you,
Brad Lyons
www.howavl.com
Old 04-01-2010, 05:12 AM
tonwurm's Avatar
tonwurm tonwurm is offline
maybe you tried that, but if not...
in the PT hardware setup go to tab 'digital' and set the input format to adat 1-8, then in the 'main' tab you can choose any input to adat 1/2...3/4..5/6 or 7/8
don´t forget to set the clock-source of your motu interface to follow the 192
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Old 04-01-2010, 05:58 AM
Hi guys,
thanks for the reply.
I used the ADat on the Digital card and 192 I/O and Motu are sync.
One think the 192 ADAT it's supporting 44.1 or have to set it 48?
Thanks again
can't get 192i/o to work with kurz ksp-8 adat i/o fourthtunz Pro Tools TDM Systems (Mac) 3 07-16-2006 04:12 PM
1622 interface on 192I/O's Legacy Port not working Halstein Pro Tools TDM Systems (Mac) 5 05-14-2006 04:27 AM
Problem connecting ADAT richsorr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 05-23-2005 12:06 PM
Trade ADAT Bridge or 888/24 fo 192i/o HughM Pro Tools TDM Systems (Mac) 3 02-27-2002 06:46 PM
Connecting 888 to ADAT? vocomotion Pro Tools TDM Systems (Mac) 2 10-30-1999 07:16 AM
