Old 08-06-2010, 03:48 PM
RKrizman RKrizman is offline
Default Muting channel when punching in?
Is there any function on any of the HD Pro Tools versions that would mute the output of a track the moment you punch in on it? For a vocal session I would like to monitor the vocal pre-converter which I could do with a little analog submixer combining the output of the preamp and the stereo mix output from Protools The mic would always be live, the singer sings along and I punch. But at that point the singer hears both herself and the recording track coming out of Protools--a comb-filtering nightmare.
I guess I could hit Mute when I hit Punch, but wouldn't it be great if this could happen automatically?
-R
rickkrizman.com
Old 08-06-2010, 03:55 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: Muting channel when punching in?
Jus highlight the section, break it & Cmd+M (or is it opt+M) on the track u need gone @ that spot...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 08-06-2010, 03:59 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
I've been asking for this forever but people don't generally seem to understand what I mean.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 08-06-2010, 04:35 PM
SWSPHX SWSPHX is offline
You don't mean mute for playback, you mean mute while a person is recording live?
If so--the only way to do that is to mute the track. You can automate the mute and draw it in so it automatically mutes at that point in the song so you dont have to keep un-muting and muting again...
Old 08-06-2010, 04:44 PM
I don't want to have to do that. That's what software is for. Bob, I'm glad you understand me, because I've been having a hard time explaining this and getting any traction on it.
I just did a test for myself, singing into my Flea 47, monitoring on headphones and comparing it being sent through the PTHD ADDA versus going directly to the headphone amp. Going through Protools made the mic's high end scratchy, sibilant, strident etc.--the comb filtering caused by the latency is readily apparent. Going straight to the amp the mic sounds exactly like it should--smooth, integrated, alluring.
People should try this comparison for themselves.
-R
rickkrizman.com
Old 08-06-2010, 04:48 PM
No that's not the problem. The problem is that when I hit record the singer will be hearing herself from the direct feed to the analog mixer, AND she'll be also hearing herself going through the PT converters on the track being recorded, fed out to the mixer in the PT stereo mix, but about 2 1/2 ms later.
This sounds terrible and defeats the whole point of trying to do latency free punching.
-R
rickkrizman.com
Old 08-06-2010, 04:54 PM
I guess I'm not totally understanding (not sayin u hav to explain) I'm jus not gettin it...
Jus meaning or tryin to get why the need for monitoring pre-converter? (I keep asking questions even after sayin u don't hav to explain )
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 08-06-2010, 05:44 PM
FajitaTone FajitaTone is offline
can't you just give the singer their headphone feed from protools, post converter?
This way they are in time with the music too, it seems to me they would be late if they hear the music post converted (has to be) and themselves pre converter.
Just sayin'.
Ray Trujillo
Freelance Audio Engineer
Old 08-06-2010, 06:00 PM
The latency isn't really enough to be much of a timing factor. The problem is that the singer hears her voice in 2 ways: through her head and from hear earphones. If the headphone send is delayed, as it is if you're monitoring through Protools, then the singer hears comb filtering caused by the 2 differently timed signals. It's not a huge deal, but it's enough to change the timbre of the mic for the singer and could result in a less satisfactory performance.
Honestly, I just compared direct versus through-PT for myself and was astonished at the difference. I think it may explain why I sometimes get boomy vocals recording myself. The comb filtering in the cans makes the high end sound more strident and edgy-bright, so I would work in closer on the mic to get some proximity effect to balance. Then I'd listen back and wonder why the recorded track sounded so dull or boomy. So now, if I monitor without the latency when I record, it will come back sounding how I expect it to.
YMMV, but I think it's worth checking it out for yourself to see if it makes a difference.
-R
rickkrizman.com
Old 08-06-2010, 06:59 PM
there are thousands of us that are monitoring thru PT all day with issues of latency so I'm not sure of that reference u made...
I'm not tryin to start anything, again I don't get why go thru so much trouble...
I kno every1 has their own way of doing things tho so I guess if it works.......
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Channel Muting in Snapshots Footy VENUE Live Sound Systems 2 12-05-2012 11:28 AM
Help with punching in ~ PT 8 maitredebas Pro Tools M-Powered (Win) 2 01-10-2009 08:00 PM
Muting channel and the SENDS... Jeff E Pro Tools TDM Systems (Mac) 15 05-21-2008 02:32 PM
punching in? sheeptuf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-28-2007 09:13 PM
MBox help - punching in w/o punching. guitthefunk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-12-2003 06:32 PM
