Old 12-24-2007, 01:19 AM
Quickkey Quickkey is offline
Default Blue Automation Breakpoints?
Hey everyone... a Noo-b to the DUC here... literally just signed up for this question. I recently upgraded to 7.3 and discovered the blue automation breakpoint that comes up every now and then... not quite sure what it is or what I am doing to create it. Just wondering if anyone can tell me. Thanks
Old 12-24-2007, 07:28 AM
BaileyBass BaileyBass is offline
Default Re: Blue Automation Breakpoints?
IN a rush here... last minute shopping. No time to explain, but just do a search for "blue" in your manual. It should come up (look for the word automation after, or somehwere around blue). The manual is a great first stop. Good luck.. SB
Old 12-24-2007, 09:01 AM
emf1138 emf1138 is offline
It just means that you've gone BEYOND the boundaries of normal automation. Ex: you drag the volume bar up to +50 (whereas the normal boundary is +12). Your max level will still be +12, you just went a little kooky when dragging. Same thing with going to INF level. If you have a region at -35 and you drag the volume bar to the "Bottom of the screen" it will show blue dots instead of black, indicating you've dragged too far. Get it? It's harmless, more of a visual indication for you.
Eric Freeman, CAS
Sound Supervisor/Re-Recording Mixer
Disney TV Animation
IMDB
LinkedIn
Old 12-24-2007, 11:20 AM
bad jitter bad jitter is offline
The volumegraph actually remembers those levels if you go above +12. If you lower the overall level you will see this. Sometimes I like this behavior, sometimes I don't.
Old 12-24-2007, 11:54 AM
. It is actually somewhat usefull, especially when in "groups". for instance, if i want to raise the overall level of the drums,(that are grouped) using, for example, a tom fader and it is at -4.. but the kick is at +8. the kick automation point turns blue when i raise the tom more than 4 db, indicating that the relative balance between that tom and the kick is no longer.. Of course I would never record drums with this relative level disparity..
When the groups are large, this comes in handy.
Mute Automation Breakpoints redlinesound Tips & Tricks 2 08-29-2010 03:31 PM
Blue Automation Breakpoints? Quickkey Pro Tools TDM Systems (Mac) 1 12-27-2007 07:16 PM
Blue Automation Breakpoints? Quickkey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-23-2007 08:18 PM
CLICKS AT AUTOMATION BREAKPOINTS ukoomrann Pro Tools TDM Systems (Mac) 4 08-29-2005 06:53 PM
