#21
Re: Waves Clarity Vx noise reduction
#22
Audiosuite only. |
#23
This is the most surprising thing about the early feedback from the big-hitters, that they are really using it real time with automation. I wonder how long that will last. I also wonder if Waves can do an update with an optional offline mode that reduces the CPU hit. Even in AudioSuite, I have to work with a 1024 buffer. No other plugin struggles remotely at 256. If it had an offline mode I'd be more than happy to work with a trade-off of being slower or buffering the audio. That's what a lot of RX plugins do, for previewing you have to wait a second or two.
Guy Rowland www.guyrowland.co.uk www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music. PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i Macbook Air M2; 24gb RAM |
#24
Maybe your audio card or system is slowing you down. I get immediate preview from RX at 1024. I'm not so sure its the plugin that is the problem. |
#25
But to be clear, 1024 works fine for me with immediate preview. It's just that 256, my normal buffer, it doesn't. It clicks and drops out like crazy.
#26
One more observation on CPU - AudioSuite is much worse than a channel insert. I have 16 threads, and I guess it distributes the mixer load more effectively than AS.
Vx Pro actually works okay at 256 if it's a channel insert, though CPU is pretty bouncy and it feels like it might drop out at any moment. But with AS it's a non-starter.
#27
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2 https://www.waves.com/r/djgsi6 |
#28
For the Mac: Go to System Preferences > Security and Privacy; Select the General tab at the top Now start Pro Tools. When a pop up window appears about not trusting the developer, click ignore (or cancel... forget which!) and then a message pops up in Preferences asking if you want to let Waves stuff through. Click Allow. Clarity now works in Pro Tools 2020 and Cubase 12 on the Mac. I also got it working in Cubase 12 on Windows. It was a strange one, I added it to my favourites folder in plugin manager, but when a project opened it had vanished. I had to manually re-add it again inside the project, and then all was well. As for Acon Acoustica, Waves isn't supported at all so I've put in a request. All my other Waves v13 plugins work in VST2 form, but VST3 makes them all crash or disappear.
#29
Only if it's left in Adaptive mode, which doesn't sound good very often.
~Will |
#30
I quite like the plugin. It seems to leave the source nicely intact.
But yeah, using it real time in a track gives some wide variation in results. I was however using it as an insert on a dialog track at a 128 buffer and didn't experience any drop outs at all.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest |
Waves new W43 Noise Reduction | nst7 | Post - Surround - Video | 49 | 09-10-2010 06:47 PM |
Waves Vuvuzela noise reduction | jeremyroberts | Pro Tools TDM Systems (Mac) | 22 | 06-25-2010 12:47 PM |
HF Noise reduction (Replacing Waves CG1) | Tim R. | Pro Tools TDM Systems (Mac) | 0 | 03-25-2007 06:15 AM |
Non-Waves noise reduction plug recommendation?? | timc | Pro Tools TDM Systems (Mac) | 19 | 05-05-2005 05:29 AM |
noise reduction,, | mmccarrell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-02-2004 08:54 AM |
