PT 8_ 'not enough cpu' warnings and freezing up
constantly get the 'not enough cpu for rtas' type warnings. but cpu usage meter rarely goes above 30-40%.
tells me to close some rtas plug ins or increase cpu usage limit. it's already at 90%. buffer at level 4, cache is minimum. and the track is always getting stuck and looping for about 5-10 seconds. then warning comes up. did a couple of bounce to disks and had no trouble, though. heard that it might be something with the graphics? i am getting more ram for the G5, so maybe that'll help? running PT 8.01 on dual 2.5g powermac w/leopard... ??? |
Re: PT 8_ 'not enough cpu' warnings and freezing up
Could be several things! which RTAS plugins do you have in the session? and have you reduced the Processors to one in the playback settings! Could also be an out of date plugin! have you checked all plugins are up to date? use this app to generate a list and copy paste here!! someone will help check the list for problem plugins... http://www.sendspace.com/pro/dl/9xyx8w Did this start when you updated to 8.0.1 Chris
The variation of this thread seems to appear anew every week.
Try lowering the processors from 2 to 1. That's the least intuitive thing in the world, but chances are, it'll fix it.
... but does it help the chorus? |
Same here! I increased the ram to 8,5 Gb, same problem!
I solved working with one cpu, but sometimes it hangs up doing anything, from opening a comment to moving a fader in automation mode, to just typing in the name of the track. It's very annoying when it happens and i'm with clients, and it happens very often after they comment about how expensive my gear is... And avidigi won't fix it for ppc user, very bad... Mancio
PT 8.01cs1, HD3, Control|24, G5 dual 2.3, 8GbRam, 2 TbHD, 10.5.8 http://www.digitallcube.it |
this should do the trick... I had the same problem until I lowered my procs from 4 to 3 then i was good to go
www.christurbiville.com |
cool. wiil try these ideas. yes, it started with 8.0.1 have been running 7.3 before this with no such problems. interesting about lowering the number of processors. do you know why this might work? thanks. |
tried dicking around with a bunch os stuff in a session haven't got any cpu warnings. rtas usage meter dropped down to around 10-11%. also increased buffer size as well. thanks to anyone who offered advice! was getting ready to replace my system with the iphone 4-track recorder... |
New iMac getting CPU warnings, but... | Samscasa | macOS | 7 | 11-29-2011 10:33 PM |
no clock warnings anymore | dave911 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-11-2010 09:18 PM |
Mac Minis -Any Warnings? | FINKSTONE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-15-2007 06:31 PM |
G5 Dual Core 2G 'Out of CPU' problems and more... | dirkB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-23-2006 02:00 PM |
getting 'out of cpu' when using Ren plugs | MrMike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-23-2002 11:49 AM |
