Old 01-03-2009, 03:49 PM
digi555 digi555 is offline
Default Can't hear midi track when recording
I have midi/instrument track, i want to be able to hear the track when i am recording with guitar. Every time i enable low latency monitoring, the track goes dead. is there anything i can do? Or is this the way protools works?
Old 01-04-2009, 03:38 AM
SeedGuy SeedGuy is offline
Default Re: Can't hear midi track when recording
Low Latency Monitoring disables any plug-ins while in record.
Old 01-04-2009, 12:31 PM
Is there a workaround for this? How can you hear your midi track so you can play with it? Do i have to dump it to an audio track first?
Old 01-04-2009, 12:44 PM
Work with your buffer set to 64 or 128.
Old 01-04-2009, 12:57 PM
paulrgmusic paulrgmusic is offline
Or...
You could BUS your MIDI tracks to audio tracks. Basically create a new audio track and set the input to a free bus (eg Bus 1 if mono or Bus 1-2 if it's a stereo track). On the midi track set the output to the same bus you chose before. Arm the audio track for recording and press record and play on the transport.
Pro Tools will then play your project and will record your MIDI track (with any effects) as an audio track. By the way, you can set up multiple tracks to record like this.
Hope this helps.
Paul
Can't hear track I'm recording on but can hear all others Durstlaw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 12-14-2022 01:24 PM
Can't monitor/hear midi by highlighting the midi track and playing the keyboard jgagne1 macOS 4 01-18-2015 08:42 PM
MBox Pro - can't hear recording track Durstlaw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-19-2014 03:23 PM
I cant hear my input track when recording PT11 gibsy Pro Tools 11 1 12-14-2013 05:18 PM
pro tools 10 i cant hear my recording/recorded track cassie11 Windows 7 11-28-2012 05:53 PM
