  #91
Old 06-27-2013, 12:17 AM
Leoslav Leoslav is offline
Default Re: Error installing required components...PT 11
There you go:
total 8
drwxr-xr-x+ 3 root admin 102 Jan 23 20:05 Macintosh HD
drwxr-xr-x+ 18 leoslav admin 612 Jan 23 21:29 Macintosh HD (original)
lrwxr-xr-x 1 root admin 1 Jun 24 11:36 Macintosh HD 1 -> /
drwxrwxr-x@ 29 leoslav staff 1054 Jun 14 13:17 Matrice Raid 1
  #92
Old 06-27-2013, 12:50 AM
Gonk Gonk is offline
Noels-iMac:~ gonksrevenge$ ls -l /Volumes
total 8
drwxrwxr-x@ 34 gonksrevenge staff 1224 23 Jun 14:13 GLYPH- 320 GB
drwxr-xr-x@ 22 root wheel 748 1 Jan 2012 Macintosh HD
lrwxr-xr-x 1 root admin 1 27 Jun 08:42 Macintosh HD 1 -> /
drwxrwxr-x 34 gonksrevenge staff 1224 23 Jun 14:13 Samples
"Are you sure what side of the glass you are on?"
www.facebook.com/thereapersofficial
  #93
Old 06-27-2013, 12:55 AM
ihoward ihoward is offline
Mine is as follows:
ihowardMBPR27gi7:~ korgman$ ls -l /Volumes
total 8
drwxrwxr-x@ 19 korgman staff 714 May 28 00:48 LaCie_HW
drwxr-xr-x+ 4 root admin 136 Jan 24 21:03 Macintosh HD
lrwxr-xr-x 1 root admin 1 Jun 27 15:37 Macintosh HD 1 -> /
drwx------ 49 korgman staff 1734 Jun 23 22:47 Pegasus R4
  #94
Old 06-27-2013, 08:53 AM
bariscicek bariscicek is offline
I encountered this exact problem on my friend's system. For him complaints are same as stated in this thread: 10.3.6 was working without any problem but Pro Tools 11 HD was not giving stated error message.
Then I came across this forum post, but there wasn't any soluition available so I tried to find the problem myself.
After some checking I think i found the culprit. This problem is obviously an I/O problem since error on system.log was related to copy/read error. So I watched the fs_usage logs of Pro Tools. Then I realized that Volume Name of my friend had UTF-8 characters. Luckily after removing these characters protools started without problem.
So my suggestion is to check fs_usage as root on terminal. Check the lines with plugin reading. Right after you might see some strange <8b> hex strings in logs. If you see that, you can fix it by unmounting your volume which includes the plugins and rename the volume name. Easy as that.
Just wanted to post the solution over here, in case some of you had a similar problem as well.
  #95
Old 06-27-2013, 09:54 AM
Unbelievable! I just renamed my main drive which has Pro Tools installed on from "Macintosh HD" to "Mac HD" and bang, it's working just fine...
I'm surprised that bug passed under the radar considering it's the default name for the drive...
Thanks a lot Bariscicek! You're the hero of the day :)
  #96
Old 06-27-2013, 01:50 PM
Any word from Avid on this solution or thoughts?
  #97
Old 06-27-2013, 02:56 PM
jryser's Avatar
jryser jryser is offline
Gonk I just uploaded another system.log to Andy. We are allegedly close!!
Sent from my PT beating heart
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
  #98
Old 06-27-2013, 03:16 PM
Thanks for the update jryser :)
  #99
Old 06-27-2013, 03:58 PM
Anyone else has tried to rename the HD? If it worked for me I'm pretty sure it should work for the rest of us...
  #100
Old 06-27-2013, 04:20 PM
jryser's Avatar
I just did and it worked for me too!
Error installing 7.4 ! jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-16-2007 12:58 PM
Email Required Error? Help with the website! samuelowen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-19-2005 09:53 AM
Initialization Error - Updated driver required Larry Younkins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-13-2005 10:25 AM
Installing 5.1.1 error deanmartinez Pro Tools TDM Systems (Mac) 0 01-17-2005 03:41 AM
error: "A Digisystem INIT is required." gloriavin Digidesign Hardware & Software 1 10-10-2003 02:27 PM
