What are you using to expand your 003 I/O?
Years ago if you had 16 channels of good mic pre, you could get something like the Alesis A13 8 channel ADAT Optical converter to get extra I/O, but they seem to be off the market. Are people using the SM ProAudio A08 box? Maybe some MOTU unit and just bypass the pre's? I don't want a more mic pre's like the digimax or octopre, I just need a way to get the extra channels. Suggestions would be helpful, thanks in advance folks.
Re: What are you using to expand your 003 I/O?
I took a slightly different route and went with a Focusrite ISA428 with the digital option card. Not only does it have 4 excellent preamps but the digital card has 4 line level inputs where you can input any analog mic pre. Right now I have a UA LA-610 patched and plan on another UA pre and a pair of API's when $ allows. Since I mix "in the box" I have not felt the need for D/A converters yet but have read that better D/A will make a difference in monitoring. You may want to check the specs on the Digimax D8 to see if it will allow line level input as it is a good deal. The SM unit looks pretty interesting as well.
apogee ensemble in standalone mode here... use it both of AD and DA conversion. the 002 conversion is awefull
I'm trying hard to not expand my 003 I/O, because I know my gear lust will cause my pocket book to lighten considerably to fill out those extra I/O slots
Apogee Ensemble is very good choice for the money Im totaly satisfaid. |
I'm using a Presonus Digimax FS - works and sound great!
http://www.presonus.com/products/Det...x?ProductId=13 I use it as the master clock and slave my 003 Factory to it. Michael
___________________________________ Pro Tools 2021 Ultimate - Native, Mac Pro 2013-3.5 ghz, 6 Core and Macbook Pro-15"-i7, 2.2 GHz UAD Apollo 16, UAD Apollo Twin Quad, Aphex 1788 Mic Pre's (16 channels), Presonus Digimax-FS, Hear Technologies Hearback, Dynaudio BM5A and BM9s Sub. |
I've used all sorts of outboard gear but I'm using the ISA 428 (with digital ADAT output) for some years now, very satisfying ! I really like the sound of the pre amps and the possibility to use it for ribbon mics. I clock/sync to the ISA 428.
Although the 003 has the possibility to swich between 2 pairs of monitors, I last year expanded the 003 with the Presonus central station for DA conversion. You can easiliy hear the difference. And I use an older UA LA2A and UA LA610 because the Bombfactory BF2A does not cut it for me. cheers, Chicken
New shoes always hurt. |
I am using M-Audio Octane, its perfect and sounds great!
I have M-Audio Octane too. It's great in more ways than one!! The inserts on each channel are great also.
For Ensemble users,
I've been curious if it would interface well with Digidesign interfaces. Everything running smoothly? Any problems? |
OMF expand | JPorter | Post - Surround - Video | 5 | 05-22-2013 04:51 PM |
Help W/Expand and Pro Tools | spidey01 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-06-2009 10:31 AM |
Expand UI bug? | mcpissto1 | Pro Tools M-Powered (Mac) | 4 | 07-31-2008 01:31 PM |
Expand question | romkey | Virtual Instruments | 7 | 02-25-2006 05:30 PM |
Where is Expand!? | MarkGriffith | General Discussion | 5 | 02-15-2006 03:27 PM |
