Delay Compensation inconsistent
I noticed that sometimes on a mix one track would send fine to an FX bus (no delay/phasing) but then I'll assign to another FX buss, and it'll be NOTICEABLY delayed with the return whilst other are fine through that return...
The plugin on that buss seems to make no difference. Sometimes happens with HW insert too. Thoughts?
Lior HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 * iPad Air/Avid control * EuCon 18.3.0.217 * |
Re: Delay Compensation inconsistent
I'm having an issue of Delay Compensation being inconsistent also.
I'm in the middle of a mix, with Delay Compensation set to Long, there is a noticable flam happening between the overhead and snare. They're both routed to busses which are routed to busses, which is routed to mix outputs. I even have the same plugins on both sets of busses. If I turn off DC, and turn it back on, SOMETIMES the problem is fixed, definitely not all the time, but ultimately, if I turn it to Off and back to Long enough times (or sometimes restarting Pro Tools), eventually it works. Any suggestions for this? It's seriously inconsistent and frustrating. and it's definitely not a problem with the tracking, or anything of that sort, as it works fine sometimes. |
Interesting. Sounds like it's much worse in your setup...
Avid?
So... I just set up a new mix, and there's A LOT wrong with ADC... Lots of flams and badness. Much like you describe.
I just realized it's the first mix since I updated to 9.0.5... Avid???
I do believe mine is 9.01
What is the maximum system delay? What is the ADC view's color? Is it red on some tracks? And which plugins do you use on the AUX tracks? And did you turn off the DSP cache, the culprit for so many problems?
I am still at 8.1.1, but I can't imagine that Avid is at version 9.0.5 with such an issue... There will be another reason for this.
Pro Tools|HDX Ultimate, 192 HD I/O, 192 HD Digital I/O, Focusrite OctoPre, Pro Tools 2021.3, Mac Pro 5.1, 24 GB RAM, Mojave |
Repairing permissions and restarting seems to have done the trick...
Where do I turn off DSP cache? Couldn't find that...
Click on the little arrow in the system usage window!
I don't have that... Maybe not an HD Native feature? I noticed you're on full HD...
Here's a screenshot: https://idisk.me.com//pqlior/Public/...51.54%20PM.png
Oh you're right, I am sorry... It's available in HD only.
Delay compensation with backline delay | chuck goodwin | VENUE Live Sound Systems | 3 | 08-09-2013 07:54 AM |
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing | CNSound | macOS | 1 | 01-27-2012 11:10 AM |
Delay compensation- choice of 'Medium delay'? | dtmprod | Pro Tools TDM Systems (Mac) | 2 | 05-05-2010 11:00 PM |
Delay Compensation in LE | VanGough | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 20 | 02-26-2007 04:47 PM |
Delay Compensation - Delay Monitoring when REC | Howardk | Pro Tools TDM Systems (Mac) | 2 | 06-18-2006 08:59 PM |
