C24 Cue Output Weirdness
When my Main->Cue is ON I can get audio in my headphones fine via my Cue. If it is off, I get nothing even though in ProTools I am sending it out my Cue Outs. So I don't even know what I'm doing wrong, If Main->CUE is off you have to send the signal to analogue 7/8 right? Analogue 7/8 input should be ent to the Cue outputs. Not sure if that's correct.
Re: C24 Cue Output Weirdness
No, you have to send it to Analog Outputs 15 & 16...
Assuming that you have Analog Outputs 15 & 16 connected to your Cue Inputs...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Yeah I don't have 15-16 hooked up on the 192. Why does the C24 I/O setup say Analogue 7/8 is cue? ProTools In on the C24, where does the analogue 7/8 go to? Is OUT 7/8 disabled?
Figured it out, yes, 7/8 are cue outputs going ot the protools in. I think I had a bus that wasn't working. I've had busses randomly stop working for some reason. Sucks Works now.
No output device selected in Studio Monitor Express, using Default Output (Mbox Pro). | Focuret | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-12-2014 07:33 AM |
Multi output instrument weirdness with native plugins inserted (10.3.2 HD on 10.6.8) | Ryan Hafer | macOS | 0 | 11-11-2012 08:27 PM |
Speaker Output weirdness | Baritonealone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-29-2008 05:04 PM |
SSC Output Weirdness | Frank S | Digidesign Hardware & Software | 2 | 07-06-2001 05:13 AM |
Adat Bridge 24 output weirdness | crsync | Pro Tools TDM Systems (Mac) | 6 | 06-20-2001 07:56 AM |
