#21
Re: PT 6.9.2cs2 Inconsistent LTC Chase
ALmost forgot, checked the drive: Hitachi Deskstar 7200RPM
And as for setting the "delay before locking to TC" it's set to 0 and no changable. I assume because I am not using serial maybe? So I am unable to set it to 10. Maybe there is a way around? |
#22
#23
#24
Whats the largest 10k rpm Seagate SATA drive you can get though? Last I checked they were fairly small.
#25
#26
The problem that we all see is definitly not HD related, because it is present in various configurations.
btw, PT 6.93cs1 showing the same symptoms with an Avant, later I can check MT too. BW |
#27
Thanks, Jordan |
#28
Jordan,
Not trying to rain on your parade or anything, but I think most of us would agree that this is something a bit more complex than a setting. There is something fundamenally wrong here that cannot be fixed by changing sofware options. I'm really not at liberty to work on the problem with you right now, as I am knee deep in some productions at my home studio, and won't be using the SSL/HD rig for a few weeks. |
#29
HDUser13, i totally agree, because we are in the darkness for a while, we already checked all setting stuff + possebilities ourself.
Jordan, we can offer You some measurement reports of our inhouse service department, they checked several Sync I/O boxes and the result is that it is flakey, that´s the reason why in two SSL rooms Sync I/O has been retired. Two other german TV station have equivalent results in their testing departments when they tested Sync I/O..so it would help if You can double check that also... For us it is really hard to understand that You have problems to repro this, when we run into this everyday a couple of times. The only room which is ultrastable is a MixCube with AV/XL + ProControl+2FaderPacks/USD and Colin Broad SR-4 as Synchronizer controlling PT + all 3 videomachine formats. BW |
#30
I agree, it would appear that something changed in Pro Tools 6.9 that's causing this. However, the fact that we can't reproduce it here leads me to believe that there is some variable, or combination of variables, that needs to be met. Adjusting settings may give us a clue as to what that is, or maybe we'll find something that improves performance (i.e. Delay Before Locking to Time Code). Any more details that you folks can provide will be much appreciated. Thanks for your patience while we get to the bottom of this.
-Jordan |
Why is PT inconsistent ?? | JLEpperson | Pro Tools HDX & HD Native Systems (Mac) | 0 | 11-26-2013 11:46 AM |
Maxim-inconsistent behavior? | danika | Pro Tools 10 | 6 | 11-07-2011 04:50 PM |
Delay Compensation inconsistent | [email protected] | Pro Tools HDX & HD Native Systems (Mac) | 13 | 09-12-2011 07:48 PM |
Inconsistent triggering for Strike | Che_Guitarra | Virtual Instruments | 2 | 09-15-2007 10:12 AM |
volume inconsistent from mac to pc with mp3 codec | Denes Pagan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-18-2004 07:16 AM |
