Old 09-25-2017, 07:13 PM
psujohnny03 psujohnny03 is offline
Default Piano sustain effect removed once clip is edited.
Hello, I posted earlier about having issues with recording my keyboard and sustain pedal together. I found out how to get the sustain effect to record but now there is a new problem. When I listen back to the recorded track it sounds great but if I edit the clip in anyway, then listen again, the sustain effect gets lost or somehow turned off and now you just hear the regular piano notes playing. Not quite sure how this is possible but if anyone can help I will love ya for it.
Pro Tools 11 Trail
Windows 10
Casio wk 225 keyboard
BOSS FS-6 sustain pedal
Focusrite Scarlette 2i2
Keyboard is plugged directly into the computer.
Old 09-26-2017, 02:04 AM
Stig Eliassen's Avatar
Default Re: Piano sustain effect removed once clip is edited.
Do you have the sustain controller lane visible when editing? It's easier to understand what happens when you edit MIDI in Pro Tools.
There's a small arrow pointing right in the colored portion of each MIDI track in the edit window. If you hover over it it says "show/hide automation lanes". Click it, and select sustain.
Old 09-26-2017, 05:09 AM
amagras amagras is offline
Use the midi editor (double click on the midi clip you want to edit) instead of editing the clips directly from the arrangement window like you would with audio.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Recording Piano but Sustain Pedal not being recorded psujohnny03 Getting Started 10 09-25-2017 05:52 PM
MIDI Record Piano no sustain pedal MarkWorsnop Pro Tools 10 1 06-17-2013 08:58 AM
Midi Piano Sustain Disappearing simpke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-06-2012 03:19 AM
Problem with recording MIDI piano sustain pedal Chris7514 MIDI 5 06-11-2008 12:56 AM
Piano sustain pedal in recording Help!! Zownd Tips & Tricks 9 04-05-2004 02:21 PM
