Old 11-27-2021, 04:46 AM
Isadore Isadore is offline
Default issues with PT 12.7 and Apollo 8
I use an external pre amp (Millennia) and PCM 90 reverb along with a Mac Mini
with Apollo 8 Dual as the interface. It had been working fine until a while back I had to send my Millennia back for repair so I started using the built in Apollo pre amp. I finally got my Millennia back the other day and hooked it back up. I've, out of habit, always used lines 7 & 8 for my mic channels and 5 & 6 for my reverb channels. For some reason line 7 was getting a weaker signal than line 8. After making sure my mics were OK, I then tried using lines 5 & 6 for my pre amp and all was good. I then tried lines 7 & 8 for my reverb channels and got no signal. I wondered if something had changed when I started using the Apollo 8 pre amps so I then reset the Apollo 8 but can't for some reason re-set the I/O path in Pro Tools because the "delete path" button won't highlight. So, if anyone has any idea what's going on I would sure appreciate it. I've hit the wall.
Bill Mize
Old 11-27-2021, 06:14 AM
Default Re: issues with PT 12.7 and Apollo 8
I actually solved the problem. The "mirror" channel on the Apollo console somehow had a db filter turned on (how, I don't know). Next question, does anyone know of a really good interface with good converters that doesn't have bells and whistles like it's own console?
Bill Mize
ProTools 2020.3 + Catalina 10.15.4 + UA Apollo issues agoraphobia Pro Tools 2020 1 05-05-2020 06:37 AM
Macbook Pro 2018 w/ UAD Apollo 8p and PT 2018.7 Performance Issues Dudiester Pro Tools 2018 5 08-12-2018 08:33 AM
Apollo i/o issues with both 10.3.8 and Protools 11 sdfalk66 Windows 9 04-22-2016 12:21 AM
PT10/11 and Apollo 16 Latency Issues Barry Johns Pro Tools 10 13 02-17-2014 06:24 PM
Issues After Updating UA Apollo Interface viktor99 Pro Tools 10 0 11-03-2013 10:36 PM
