Hello Folks,
Sorry for the newbie question but can anyone tell me what are the keyboard shortcut for: Bypassing all inserts of all channels at once if there is any ... Bypassing inserts on only one channel Help is much appreciated Thanks
System Details: iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz macOS 11.6.2 Pro Tools 2021.12 Logic Pro X Reason 11 UA Apollo 8p Apogee Thunderbridge/Apogee Symphony I/O 2x6 Eleven Rack/Focusrite ISA Two/Onyx 1640i UAD Satellite Quad MOOG Mother 32 Nektar Panorama P1 Axiom AIR 49/Axiom 49/Yamaha P35 Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e Genelec 8040b/Yamaha HS80s/M-Audio BX5a Beats Solo/Shure SRH1840/Slate VMS https://open.spotify.com/artist/7KfV..._branch=1&nd=1 |
There is many shortcuts to bypass inserts and sends : - some using the mouse (ctrl + clic on an insert or a send will bypass all inserts/sends below) - some using keystroke : you must select one or many tracks first, and then hit the shortcut (shift+ A or Q or 2 to 5). You can bypass all inserts, all sends, only A-E or F-J, EQ only, Dynamics only, Reverb only, Delay only, etc… In Pro Tools, go to menu "Help" and choose "Pro Tools Shortcuts.pdf" then hit 'Help' to open index and search toolboxes. You will have all the details. NOTE : since PT10.3 and PT11, ctrl + clic is sometimes different from mouse's right-clic on Mac
Macbook Pro (Core2duo 2,4GHz RAM4GB SSD) MacMini (Core i7 Quad@2,3GHz RAM16GB SSD) PT 10.3.10 + PT12.4 / VEP5.3.1 / MacOSX.9.5 (MBP) PT12.4 / VEP5.3.1 / MacOSX.11.1 (MBP) PT 10.3.10 / PT11.3.2 / PT12.4 / VEP5.3.1 / MacOSX.8.5 (MM "Production" on SSD) PT 12.4 / VEP5.3.1 / MacOSX.11.1 (MM "test" on HDD) RME UFX (USB2 with MM and Firewire with MBP) + Vienna Ensemble Pro Server on PC Q6600/8Gb/Win7-Pro64-SP1 Last edited by demodigi; 10-25-2015 at 03:04 AM. Reason: Note added |
Can you still make customized shortcuts on PT12? | thierryhenry | Pro Tools 12 | 7 | 10-22-2015 02:31 PM |
PT12, Win 7 - Frequently lose keyboard shortcuts | Eric Klinger | Pro Tools 12 | 7 | 06-28-2015 01:21 PM |
A-Z keyboard shortcuts for GROUA-Z keyboard shortcuts forPS in the SECONDS ID group.. | jessedtf | Pro Tools 10 | 6 | 10-24-2012 10:42 AM |
Keyboard Shortcuts-Apple Thin Keyboard | Brian in Charlotte | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-15-2008 04:17 PM |
Keyboard shortcuts with foreign keyboard | torsig1967 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-08-2006 06:06 AM |
