Old 01-11-2011, 03:52 AM
busk busk is offline
Default midi recording - note durations
When recording tracks using a midi keyboard the notes are not recorded the way I play them. All the durations show up as a 1/32 note. I've had to use the trim tool to lengthen the durations.
The session was open with a template. Audio recordings are fine, it's the tracks like drums, pad and piano which are being generated with the xpand2 plug in.
I've been all through the manual looking for clues, but haven't had any luck yet. Any suggestions?
Old 01-11-2011, 06:07 AM
Murt Murt is offline
Default Re: midi recording - note durations
Check to see if 'Input Quantize' is enabled. 'Event>Event Operations>Input Quantize.
If it is, disable it by unticking this option.
MBox2Pro / LE 8.0.5
Old 01-11-2011, 08:51 AM
That did it. Thanks a bunch. I never would have been able to find the solution using the reference guide. The description of input quantize is pretty slim.
Thanks again.
Unknown MIDI note appear after recording HELP! Boogie457 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 03-23-2015 03:43 AM
1/64 note latency when recording MIDI to Audio Jean-Michel MIDI 1 05-21-2009 11:28 AM
When recording throough USB MIDI, first note is cut.... Justbleazy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-01-2009 10:02 AM
Extra Note - at beginning of Midi recording Arkitorture 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-02-2006 03:39 PM
MIDI recording - lost first note tribase Tips & Tricks 0 03-10-2006 09:49 PM
