#21
Re: my master volume is in red...
MBox2Pro / LE 8.0.5 |
#22
I tried to show in my explanation how the trim would work if inserted before the rest of the plugs as to compared to using it after them, obviously recording a guitar that clips at -3dB is far too hot. You need to be careful not to clip the signal at the plugins. If (as I now think you mean) none of your tracks actually peak but the master fader peaks, you said to insert a trim after all the plugs to bring the level of each channel down until the master doesn't peak? I wouldn't recommend fixing the problem that way, I would do it by grouping all the tracks together, then as you bring one down, all the others will automatically come down as well keeping in proportion with how you mixed it, so your mix will never change doing it this way. This way is much much quicker in many ways, takes seconds to do/adjust as you only need to move one fader. Also, in LE, you could simply bring the master fader down until it isn't clipping due to it using floating point maths, but you couldn't do that in HD as it uses fixed point maths. |
#23
I use an AUX for a master, because of the pre post insert FX thing. I don't want different compression as the master volume is faded.
Before the "master Aux" I have another master fader to trim it if I need to. TH |
#24
That's interesting, I never knew that the master channel inserts were post fade, just checked it with a trim plugin, seems a bit weird.
#25
actually it's a mixture of both, even stranger
#26
there's bunches of things you COULD do...
-if you know exactly where the peaks are coming from (ie., some super hard snare hits), start by turning that track down a bit and see what happens to your mix... maybe it's just simply too loud (or recorded oddly). -compress those tracks to where they still sit nicely, but don't lose their vibe. -automate the volume on just those hits that are causing the peaks (such as wild snare hits that may be popping out of your mix). -copy/paste non-peaking elements of the same type (ie., replace a snare hit that doesn't peak with the one that does) -keep things simple (not the best, but simple) and select the "ALL" icon in the group selection zone (assuming you don't have automation going on), turn all your tracks down uniformly until there are no peaks on the master, (make sure your mix is still decent), and then put a limiter on the master at -.01db and bring down the threshold until it starts hitting about -3db and listen for distortion... if none, don't be afraid to push it depending on the kind of music your making (and limiter you're using). if you select the 'ALL' group and bring everything down, make sure once you have everything sitting well, turn off the 'ALL' grouping button and bring the master, stereo audio track and aux tracks, etc., back up to 0db as well. -that's just a few things that are possible... this last suggestion has it's own inherent issues, but hopefully might give you the best and easiest solution to solve your master peaking/clipping issues. good luck g |
#27
you're all very funny...
do you remember guys i created this topic and nobody answered my LAST question ? |
#28
do you mean that for example you have a compressor on the master volume and when you lower it the compression is changing proportionnaly ?... cause this is a problem for me too !!! so you use an Aux ? how do you do ? you assign all your tracks to that Aux ??? any other things i should know to do that properly ?
#29
to answer your last question... yes, in the digital world, generally it is a problem if your master track is reading in the red. whether you hear distortion or not, it means you're master is peaking and/or clipping to some degree.
all the suggestions to your post have been helpful if followed to suit your needs. if you just put a limiter on your master track, you may still hear distortion if you push it too hard, but no matter what, if you set the gain at -.01, you will never peak (red-line) your master track. good luck. g |
#30
"""""so i read this article (with my bad english) which seems very interesting.. so lets say all my sources are recorded in green... does this article says that even if all my individuals tracks are in red i just have to lower the master volume fader to obtain a very clean signal ? to obtain the EXACT SAME signal of all individuals tracks as if they were in green ???"""""" |
Master Volume | garybobb51 | Getting Started | 3 | 06-21-2013 01:53 PM |
master volume | cowpoke | Pro Tools SE and Essential (Win) | 0 | 01-26-2011 05:33 AM |
Master Volume | bderkach | General Discussion | 2 | 02-27-2003 03:12 PM |
master cd volume too low | Paul Curtiz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-04-2003 12:33 AM |
I need a Master Volume box | Armando | Pro Tools TDM Systems (Mac) | 10 | 05-03-2002 05:48 PM |
