T-Racks EQ authorization
Seems like I did everything they asked for, step by step, got the email from IK with my code, entered it in the authorization box that pops up when adding the eq for the first time, hit OK, and i get an error message saying "Please check authorization code!".
Whassup........
www.myspace.com/krou |
Re: T-Racks EQ authorization
I had the same thing with AutoTune last night, kept enter the code and was told that it had failed.
Cancelled which quit Pro Tools, reloaded and everthing is fine and AutoTune is authorized. Try doing the same it might work, if not then I have no idea. Lee
P4 2.8 1Gb RAM XP Home PT LE 6.1.1 Digi 001 --- |
Had the same prob.
You cant copy from the email using apple c, apple v Just type it in yourself, that fixed mine. |
mmm.....will do. Thanks.
I had problems the first couple of times as well. I had the Authorization Code and the "other" code mixed around. Once I got the right code in the right spot, all was well. Seems I was able to use copy/paste for some of is, but had to type the rest.
Good luck, ~Cheers~
|OS 10.2.8|80gb ATA100|120gb ATA100| |Mac|FW800|DP 1.25ghz|1.5gb Ram| |PTLE 6.1.2|Digi002r|Digimax| |Recent PC to Mac convert| |
PK Hat:
Hey, if you are using Mac OSX see below. Go to your HD then open your Applications folder and then load Text Edit. Now in the text window enter this below. Reg.Code: Enter your Auth/reg code here for T-racks Serial #: Enter your serial # here. T-racks Now save the file as T-RackS Preferences (this is case sensative type it exactly) NO Extentsions. Now go to File > save as then save this file in your HD > Users > Your Name> Library > Preferences folder. Now try your codes.
Jason Williams / Technical Support IK Multimedia U.S. Division Email: [email protected] |
T Racks EQ keeps asking for AUTHorization??? | sweet9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-18-2010 01:13 PM |
T-RackS Comes to TDM | PastaViking II | Pro Tools TDM Systems (Mac) | 0 | 01-24-2005 03:44 AM |
T-Racks 24 or T-Racks Plugs? | hookiefree | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-08-2004 01:18 PM |
Please Help with T-Racks | 1245 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-04-2004 09:37 AM |
I'm using T-Racks and I have a problem...Anyone else using T-Racks that can help??? | wcody | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-24-2000 08:34 AM |
