Old 01-06-2023, 05:17 PM
colinato colinato is offline
Default Session Created in 2022.10 will not open in 2022.12
I updated to 2022.12, including the HD Driver, from 2022.10 and had the following issue.
When opening sessions created in 2022.10, Pro Tools would crash during the "restoring tracks" process. Seemed to stall every time when it reached the auxes I have set up for fold downs, no down mixing plugins, just Pro Tools bus fold downs.
Tried multiple sessions, all suffered the same fate. I rolled back to 2022.10 and everything works again.
I was able to create new sessions in 2022.12, which seemed to work fine.
Pro Tools 2022.12 running under Rosetta 2
Avid MTRX - HDX 2
Mac Studio
Monterey 12.6.2
Old 01-06-2023, 06:55 PM
mattrixx mattrixx is online now
Default Re: Session Created in 2022.10 will not open in 2022.12
Are you able to import the 2022.10 session files into a blank 2022.12 project, as an alternative?
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 01-08-2023, 09:26 AM
I rolled back before trying this. If I give it another go, I'll give this a shot if needed. Thanks!
Old 01-08-2023, 10:29 AM
noiseboyuk noiseboyuk is offline
Sounds like a corrupted install. I’d uninstall 2022.120, restart, install 2022.12, restart and see how that goes. The restarts definitely make a difference for me.
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Old 01-10-2023, 12:34 PM
loud neighbor loud neighbor is offline
I've also been having issues opening 2022.10 sessions with 2022.12 - resorting to importing tracks into new sessions a handful at a time but even then it's been buggy - quitting at random times upon re-opening.
Going through plug-ins (which are all up to date) trying to find a culprit there but after seeing this I'm hoping it's just a bad install of 2022.12 - I'll try the above re-install suggestion and report back.
Old 01-27-2023, 06:57 AM
Noyan Noyan is offline
Same here with the Ultimate on both Mac Studio Max and MBP M1 Pro. Rolled back to 2022.7 on both systems.
Old 01-27-2023, 07:29 AM
A re-install of 2022.12 did not solve the issue for me.
My original post was regarding a Mac Studio on Monterey. I have since tried installing on another machine, iMac Pro on Big Sur. Having the same issue. I am able to open some sessions but not others. Haven't figured out the culprit yet.
Old 01-27-2023, 12:38 PM
s.d. finley s.d. finley is offline
I had that issue with a session updating from 2022.6 to 2022.10. It tuned out that the session was corrupted. Try creating a new session and use the import data function.
sdf
www.sugarhillstudios713.com
How to open a Protools 8 session in 2022! DBHILL77 Pro Tools M-Powered (Mac) 3 11-01-2022 05:23 PM
Opening a session created in 2022.10 in 12.7.1 Brandonx1 Post - Surround - Video 5 10-27-2022 10:13 PM
Will sessions created in 2022.9 open in 2022.7 michael c Pro Tools 1 10-21-2022 09:09 AM
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] Dizzi45Z Pro Tools 43 05-29-2022 03:59 AM
