Latency problem with TC-Helicon VoiceWorks?
Hi, I'm thinking of buying this unit for vocal processing, currently running Powermac G4 3.6 (Silver door model) 1.25 GHz Processor G4 with 1BB L3 cache, RAM: 768. Running: MAC OS X 10.4.3. Also 002 Rack with ProTools version: 7. I understand there are no problems in realtime, but when I run the VoiceWorks as an external effect during subsequent mixing/editing, is it true that I will have a "variable latency" (delay) problem?
Thanks |
Re: Latency problem with TC-Helicon VoiceWorks?
Connecting S/PDIF, I can't say for sure. Don't know why it would be variable, at least not varying during playback. The latency of the 002 itself should depend strictly on your hardware buffer setting. For analog i/o, I've made an html chart showing delays in samples for each buffer setting at each sample rate:
http://www.elvenminstrel.com/recordi...tencychart.htm My understanding is that latencies through digital connections are shorter, but I don't know exactly how much shorter. Probably by the D/A and A/D conversion times, which appear to be 87 or 88 samples. Not sure if that is one way or both ways. The TC unit itself will obviously take a short amount of time to do its digital thing, too, so total roundtrip latency may vary with how much you're demanding of it at any given time. More harmony voices probably mean longer processing times, and thus more latency from the TC itself. That has been true of every digital harmonizer I've ever used.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Thanks for the useful info. I think I might go ahead and buy this unit - my vocals are the weak link at the moment, and this seems to have a number of features which will hopefully make them tolerable. To my family, at least!
TC Electronics VoiceWorks | Jon Martin | VENUE Live Sound Systems | 1 | 06-30-2007 03:41 PM |
TC Helicon | macr0w | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-12-2005 10:27 PM |
Connecting TC VoiceWorks to 002 Rack-Please Help! | John Dough | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-23-2005 02:23 PM |
Waves Plugins or TC VOICEWORKS unit | aprim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-27-2004 06:05 PM |
Anyone using TC Helicon Voiceprism ? | stevegalante | General Discussion | 13 | 07-26-2001 05:21 AM |
