I need beats
HELP! I need some beats. I have the following:
1. Mac G4 running PT LE 5.1 2. Emu E6400 Ultra 3. Novation supernova rack II 4. Midi keyboard 5. Midiman 8x8 I am looking to work on drum sounds in my music and have reached a dead end. I am fed up of hitting weighted keys to trigger crappy drum sounds through my sampler. (I only have a few sample cds) In delving into the world of percussion I have been overwhelmed with the number and types of products available. Pro tools isn’t for programming drums. I have read other posts that you can use Logic in conjunction with pro tools is this my answer? Should I be looking at sequencers to run with my sampler and investing in some hot sample cds? budget approx £600 |
Re: I need beats
What style music? Do you need live drums or loops?
Re: I need beats
Hi
My stuff is mainly acoustic and I want to add some live and electronic drum sounds to this. I dont like the idea of using loops as anyone could use the same loop. Is this just naive? I hope I have made myself a bit clearer. Basically I want to be able to program live drum sounds in the same tempo as my audio in pro tools. Is there anything out there for me? |
Re: I need beats
Although there is a learning curve, I've found that Reason can do a great job using real drum samples with a lot of options for expression.
God Save Mrs. Mopp |
Re: I need beats
I have read about native instruments battery and understand you can rig it up with a midi drum trigger unit such as the akai MPD-16. But I get the impression that you get much better results from programming the drums so they are fully quantised, obviously you want to keep that "feel" to the rhythm, but I think this is more the road I am looking towards.
I am not sure if I should be looking to a piece of hardware or software. I will have a read up about reason cheers |
Re: I need beats
"Real" sounding drums = Yamaha Motif Keyboard
but it'll cost about 1,500 for the "smallest" version.If your looking to go cheaper i'd suggest Battery software from NI around 3-500 i'm guessing......JMHO |
Re: I need beats
I use Ableton Live 2 to put together my drum tracks from sample loops.
Only draw back is that it doesn't have have a direct interface into ProTools yet. Once PT supports ReWire (Live already does) things will be much smoother. Right now I import my Live tracks into PT.
2013 MacPro 3.5GHz 6-core/16GB RAM/OS10.9.2 - PT10.3.8/PT11.1.2 - RME UFX - Apogee Rosetta 200 - and a bunch of other stuff. |
Re: I need beats
Re: I need beats
I just purchased the MO rack and it has the best sounds in one roof you can find. well worth the money i spent. as far as the other features it couldtake you years to learn em all.
Dell Dimmension 4550, P4 2.5 768mb ram, MPC 2000xl, Yamaha SY85 synth, Yamaha Motif rack, Event Bas 20/20 monitors Quill steno note book, Bic pen, #2 Skilcraft pencil |
Re: I need beats
Reason, Battery, or Ableton Live.
Pick your poison. They're affordable, easy, and can give you killer drum tracks if you use good samples.
www.myspace.com/krou |
Can I use my own beats? | Cracka2HI! | Pro Tools SE and Essential (Win) | 5 | 03-07-2010 03:51 PM |
beats in pt | markrenner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-03-2007 03:46 PM |
Rap/Hip Hop Beats | Room24Prod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-12-2004 04:49 PM |
HELP! My mom beats me! | Barhab | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 88 | 06-18-2004 07:13 AM |
I want big fat beats....... | jason66213 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 02-27-2002 12:18 AM |
