Old 06-13-2007, 05:21 AM
maxserg maxserg is offline
Default Problems with FST Connect and PT 6.4.1
When I transfer from Adat FST Connect to my hard disk (24 Bits session 44,1KHz, aiff), everything seems to work fine. Then I create a new session with PTools(24 Bits/44.1KHz, .aiff) I import audio. At the import window, the audio files appear as 16 bits, the description of the file says that PTools has to import the file because it cannot be used directly. Then after the progress bar has ended, there is an error message" Could not complete the "convert and import" command because: attempt to position mark before start of file (-40) while writing track.
I have to say that I didn't create audio tracks inside the session.
I did import the same audio inside Digital Performer with no problems and the tracks played perfectly.
Clues?
Thanks guys
Mac OS 10.3.9 dual G4-800, 1,5 gigs ram, ProTools TDM 6,4.1
Old 06-13-2007, 04:48 PM
Default Re: Problems with FST Connect and PT 6.4.1
Bump!
Old 06-14-2007, 04:48 AM
And I have the latest version of FST Connect.
With .wav files comming from fst, PT sees now 24 bit files with no cure to import
Connect PC to MAC TDM Mix + synchro problems smcoptyltd Pro Tools TDM Systems (Win) 5 02-14-2007 04:46 PM
can i connect another 888/24 without problems? fucdemas Pro Tools TDM Systems (Mac) 1 11-11-2004 11:38 AM
Direct Connect Problems rat1016 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-21-2002 08:50 AM
more problems--direct connect Blake Henderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-19-2001 11:06 PM
Problems with direct connect Genaro Hurtado Tips & Tricks 1 04-18-2001 12:49 AM
