Old 07-13-2020, 05:56 PM
NateAlexander NateAlexander is offline
Default Insert Time But Ignore Some Clips/Tracks?
Anyone know if it's possible to lock certain clips from insert/cut time?
I always assumed either the edit/time lock function did this but doesn't see to work for me
Old 07-14-2020, 07:05 AM
Default Re: Insert Time But Ignore Some Clips/Tracks?
Hmmm, I'm not aware of a way to do this. What's the end goal here? Maybe Insert Time is not the right tool? In any case, its pretty easy to move a few clips afterwards. In all the times I have used this function, I haven't had the need to exclude anything(but of course, your needs may be different).
Old 08-08-2020, 03:08 PM
well the end goal is editing a cue for a film (like if you get a new reel)-- if you can cut time on everything but the video and guides it would make things WAY easier!
Old 07-26-2022, 05:27 PM
gills gills is offline
I think the current best way to do this is to hide the tracks you want to protect just before the Cut/Insert Time operation, then unhide them.
Here's a quick method for that:
Create two memory locations — not as markers, but the kind that saves the state of visible tracks. (In the New Memory Location popup, select Time Properties > None, and General Properties > check Track Visibility).
One memory location shows all tracks, and the other hides the tracks you want to protect from the Cut/Insert Time operation.
Ideally these memory locations are numbers 1 and 2. You make your selection, then use the memory location shortcut to hide the tracks you want to protect (on the numpad press . then 1 (or whichever memory location number you set it to be) then . again).
Do the Cut/Insert Time operation, then use the shortcut for the other memory location to show the hidden tracks again.
Old 07-26-2022, 07:50 PM
smurfyou smurfyou is offline
Make a group with all the tracks except video and guide.
~Will
How to move all tracks/clips at one time pforbess Pro Tools 10 4 07-29-2016 11:26 AM
Drag clips from severals tracks to one same tracks simonyeah Post - Surround - Video 19 03-04-2016 01:28 PM
Gap time between clips paulo m macOS 2 09-04-2013 04:38 PM
How do I automatically insert a plugin on all tracks at the same time? Undertones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-29-2010 01:21 AM
How to insert time / insert measures, without upsetting tempo map and markers imp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-25-2003 05:45 PM
