Using Outboard with PT11 and UAD Apollo Console 2
So, I've been on a UAD Apollo and PT10 system for a while and happily using my analog outboard (via insert i/o sends) with zero latency problems.
I have just made the switch to Console 2 and PT11, and now I am experiencing latency using the same analog outboard (via insert i/o sends). What am I doing wrong? |
Re: Using Outboard with PT11 and UAD Apollo Console 2
Are you using PT mode in the new UAD software (it was actually there before the new console s/w)? And if so is your system properly set up? And do you still have that 4 gig of ram your profile says? PT11 really wants to see 8 gig or better. You're always going to have latency when using outboard hardware. No way around it except to nudge tracks after they're recorded. |
With the Apollo, the I/O is done inside the hardware before it goes to the software. Of course there is the playback latency through the FW port but that is compensated for. I did not experience hardware I/O latency with my Apollo unless I was also using that same outboard for recording AND playing back. Then it was the 15ms latency, which for verbs and such isn't really a problem when recording. Sometimes a 15ms predelay on a verb sounds nice.
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2. |
make sure you turn Low Latency monitoring on in PT and have input monitoring off so that you only monitor the new signal through Apollo
I have the Console settings set to PT Mode (PT Legacy). I have my system patched and i/o set up the same as when I was running PT10. I was actually under the impression that analog hardware outboard has zereo latency, and that one only needs to deal with latency with digital based outboard. My setup worked before switching to PT11 and Console 2. |
I agree that conversion causes latency, but I think that should be accounted for by delay compensation. Regardless, my rig was working with PT10 and Console 1, but not with PT11 and Console 2. |
You don't need a processor chip to cause latency delays. ALL circuitry has delays, analog or digital. You may not hear it as a delay but it's there. Compressors have delay and the worst I know of is the LA2A. |
Marbles well and truly scrambled... PT11 with UAD apollo | stephen duffy | Pro Tools 11 | 2 | 01-18-2015 05:34 AM |
ER - Expansion Pack - PT11 - Apollo Interface - MAC OS X Maverick | JBMusicLux | Eleven Rack | 0 | 08-24-2014 12:18 PM |
Routing Synths Using Apollo Console | Jurupari Man | Pro Tools Express on Mac OS X | 0 | 11-14-2013 07:03 PM |
PT11 compatible UA Apollo interface? | djkikis | macOS | 4 | 07-05-2013 07:44 PM |
Symphony couldn't do it-Could Apollo/PT11? | Barry Johns | Pro Tools 11 | 26 | 05-03-2013 04:28 PM |
