error 6101 / 9128 CPU overload MAC PPC G5
Having trouble with error codes 6101/9128. CPU overload, remove some plugins e.t.c. Only happens with higher track count, I open a song with 4-5 tracks and a few plugins and seems fine but with larger track counts ( say 10-15) is when it starts playing up. CPU usage is only around 40% at most. tried all the optimizations recommended through Avid, to the best of my knowledge, reinstalled protools, updated drivers for profire still to no avail. Any help would be greatly appreciated. Specs below.
Protools M Powered 8.1 Profire 2626 Power Mac G5 OSX 10.5.8 Leopard Model Identifier: PowerMac7,3 Processor Name: PowerPC G5 (2.2) Processor Speed: 2 GHz Number Of CPUs: 2 L2 Cache (per CPU): 512 KB Memory: 8 GB Bus Speed: 1 GHz FireWire Bus: Maximum Speed: Up to 800 Mb/sec ProFire 2626: Manufacturer: M-Audio Model: 0x10 GUID: 0xD6C0404000002 Maximum Speed: Up to 400 Mb/sec Connection Speed: Up to 400 Mb/sec Sub-units: ProFire 2626 Unit: Unit Software Version: 0x100C1 Unit Spec ID: 0xD6C Serial-ATA Bus: Maxtor 6Y250M0: Capacity: 233.76 GB Model: Maxtor 6Y250M0 Revision: YAR51FW0 Serial Number: Y61A2Y9E Removable Media: No Detachable Drive: No BSD Name: disk1 Protocol: ata Unit Number: 0 Socket Type: Serial-ATA Bay Name: "A (upper)" Mac OS 9 Drivers: No Partition Map Type: APM (Apple Partition Map) S.M.A.R.T. status: Verified Volumes: OSX: Capacity: 233.64 GB Available: 195.63 GB Writable: Yes File System: Journaled HFS+ BSD Name: disk1s3 Mount Point: / Serial Number: Y61A2Y9E Removable Media: No Detachable Drive: No BSD Name: disk1 Protocol: ata Unit Number: 0 Socket Type: Serial-ATA Bay Name: "A (upper)" Mac OS 9 Drivers: No Partition Map Type: APM (Apple Partition Map) S.M.A.R.T. status: Verified Volumes: OSX: Capacity: 233.64 GB Available: 195.63 GB Writable: Yes File System: Journaled HFS+ BSD Name: disk1s3 Mount Point: / SECOND HARD DRIVE Serial-ATA Bus: ST31000340AS: Capacity: 931.51 GB Model: ST31000340AS Revision: SD25 Serial Number: 9QJ3SBX1 Removable Media: No Detachable Drive: No BSD Name: disk0 Protocol: ata Unit Number: 0 Socket Type: Serial-ATA Bay Name: "B (lower)" Mac OS 9 Drivers: No Partition Map Type: APM (Apple Partition Map) S.M.A.R.T. status: Verified Volumes: Protools: Capacity: 931.39 GB Available: 924.74 GB Writable: Yes File System: Journaled HFS+ BSD Name: disk0s3 Mount Point: /Volumes/Protools GRAPHICS/DISPLAYS GeForce FX 5200: Chipset Model: GeForce FX 5200 Type: Display Bus: AGP Slot: SLOT-1 VRAM (Total): 64 MB Vendor: NVIDIA (0x10de) Device ID: 0x0321 Revision ID: 0x00a2 ROM Revision: 2060 Displays: Acer X193HQV: Resolution: 1366 x 768 @ 60 Hz Depth: 32-Bit Color Core Image: Hardware Accelerated Main Display: Yes Mirror: Off Online: Yes Quartz Extreme: Supported X193HQ: Resolution: 1366 x 768 @ 60 Hz Depth: 32-Bit Color Core Image: Hardware Accelerated Mirror: Off Online: Yes Quartz Extreme: Supported MEMORY DIMM0/J11: Size: 1 GB Type: DDR SDRAM Speed: PC3200U-30330 Status: OK Manufacturer: Unknown Part Number: Unknown Serial Number: Unknown DIMM1/J12: Size: 1 GB Type: DDR SDRAM Speed: PC3200U-30330 Status: OK Manufacturer: Unknown Part Number: Unknown Serial Number: Unknown DIMM2/J13: Size: 1 GB Type: DDR SDRAM Speed: PC3200U-30330 Status: OK Manufacturer: Unknown Part Number: Unknown Serial Number: Unknown DIMM3/J14: Size: 1 GB Type: DDR SDRAM Speed: PC3200U-30330 Status: OK Manufacturer: Unknown Part Number: Unknown Serial Number: Unknown DIMM4/J41: Size: 1 GB Type: DDR SDRAM Speed: PC3200U-30330 Status: OK Manufacturer: Unknown Part Number: Unknown Serial Number: Unknown DIMM5/J42: Size: 1 GB Type: DDR SDRAM Speed: PC3200U-30330 Status: OK Manufacturer: Unknown Part Number: Unknown Serial Number: Unknown DIMM6/J43: Size: 1 GB Type: DDR SDRAM Speed: PC3200U-30330 Status: OK Manufacturer: Unknown Part Number: Unknown Serial Number: Unknown DIMM7/J44: Size: 1 GB Type: DDR SDRAM Speed: PC3200U-30330 Status: OK Manufacturer: Unknown Part Number: Unknown Serial Number: Unknown
Hardware Overview: Model Name: Power Mac G5 Model Identifier: PowerMac7,3 Processor Name: PowerPC G5 (2.2) Processor Speed: 2 GHz Number Of CPUs: 2 L2 Cache (per CPU): 512 KB Memory: 8 GB Bus Speed: 1 GHz Boot ROM Version: 5.1.8f7 Serial Number (system): YM5090XXQPP Hardware UUID: 00000000-0000-1000-8000-0011246EBA20 |
error 6101 / 9128 CPU overload MAC PPC G5 | johnsongs74 | Tips & Tricks | 10 | 04-18-2011 04:03 PM |
error 6101 / 9128 CPU overload MAC PPC G5 | johnsongs74 | Pro Tools M-Powered (Mac) | 0 | 04-12-2011 05:20 AM |
Error Message (-6101) & (-9128) | aldeaproducciones | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 02-18-2009 08:20 PM |
6101 and 9128 CPU overload errors with 1 track!!! | organik | Pro Tools M-Powered (Mac) | 38 | 12-30-2006 12:18 AM |
cpu error 6101&9128 | gIbson_19 | Pro Tools M-Powered (Mac) | 0 | 10-30-2006 12:40 AM |
