Physical RAM is running low [ERROR]
I am getting the error "Physical RAM is running low. For better performance, install more RAM."
I am running MacOS Mojave 10.14.3, 32GB RAM, Pro Tools 2018.12.0 and it started when loading EW Play 6.0.9 - never saw it before. While HW Monitor shows Memory used 13,80 GB and Cached Files 10,51 GB and Swap Used 0 bytes, Pro Tools shows 100% memory used. Since there are reports of the same problem with different plug-ins and also in previous versions of Pro Tools it may be a Pro Tools memory allocation issue. Perhaps someone from Avid could comment? |
Re: Physical RAM is running low [ERROR]
Also EW Play is not yet considered compatible with Mojave. |
One tip that do wonders for me is to turn off Reverb Multithreading from EW play settings menu . This releives a lot of weight from the plugin processing . I use it on mojave too and with this setting enable i got a lot of performance issues .
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Physical RAM is running Low error | notedmusic | Pro Tools 11 | 19 | 01-14-2022 02:53 AM |
Physical RAM is running low | mattrixx | Pro Tools 12 | 6 | 01-23-2019 11:56 AM |
PT 10HD Physical RAM is running low | Annas | Pro Tools 10 | 11 | 03-09-2017 09:14 PM |
PT HD 10 physical ram running low? | garnoil | Post - Surround - Video | 16 | 02-23-2017 05:53 AM |
Physical RAM Running Low | Fuzzyc | Windows | 7 | 02-18-2013 05:32 PM |
