Old 09-17-2013, 01:35 PM
JGlen JGlen is offline
Default Question about installing 11.0.2 SOLVED
I currently run PT 11.0.1 and PT 10.3.6 and want to install the 11.0.2 update. Avid recommends I uninstall PT 11 prior to installing the update, and that 11.0.2 is a "Full Installer".
Am I correct to assume I need to uninstall everything related to Pro Tools in my Windows uninstall program (including the virtual instruments & plugins)?
Will the 11.0.2 update also include PT 10?
Thank you!
Edit, I did a further search and found my answer.
ADK Quad Pro, Intel Core i7 3770 IVB 3.5 Ghz, Windows 7 64
Seagate 500G Sata 600 OS Drive, Seagate 1 TB Sata 600 Audio Drive, 8 gigs of ram, 700 watt Coolermaster Silent Pro power supply. Apollo Quad Interface, Burl B2 ADC, Dangerous D-Box, UAD 2 Duo, Avalon 737, UA 610 MK II, UA 1176 LN Hardware, Focal CMS 65 monitors, and a bunch of other stuff.
Old 09-20-2013, 05:31 PM
yogoshu yogoshu is offline
Default Re: Question about installing 11.0.2 SOLVED
Can you share the answer you found please?
Old 09-20-2013, 08:55 PM
I continued to search other threads and learned that inspite of Avid's direction to uninstall previous versions, it is apparently not necessary. So I installed the update over the existing PT 11.
Old 09-22-2013, 11:34 AM
Wizzoboy's Avatar
Wizzoboy Wizzoboy is offline
You should uninstall 11.0.1 first. The 11.0.2 is a full installer. When I tried installing 11.0.2 without uninstalling all it did was update 11.0.1, but missed out the installation of TC/E and probably some other things as well. A clean install is the way to go.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring.
Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n
Old 09-22-2013, 12:08 PM
jryser's Avatar
jryser jryser is offline
Two ways to uninstall. One is to drag the app to the trash. The other is to uninstall using the dmg (if u r Mac).
Sent from my PT beating heart
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
Old 09-24-2013, 07:01 AM
lrankine lrankine is offline
Ok, tried going the recommended route of uninstalling 11.01 which kept giving me Elastic Audio errors. After reading this thread I reinstalled 11.0 and then installed 11.02 over that which worked.......sort of. It only takes 8 plus minutes for 11.02 to boot up. WASUP W'DAT??????? Not sure what to try now.......any suggestions?
Old 09-24-2013, 07:30 AM
clausiii's Avatar
clausiii clausiii is offline
I mentioned that the very first boot takes always longer than all others after that because PT reconfigures at first boot (i guess).
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 09-24-2013, 01:24 PM
That's not it my friend. I get this every time I load up 11.02. So if I may be so bold.........WHERE IS TECH SUPPORT ON THIS??????
Old 09-25-2013, 04:13 AM
Ok......FINALLY fixed it with the uninstall, install, add the Elastic Audio plug in back into the plug in folder. But WHY are we having these problems to begin with........
Problem installing PT 10.3.5 [solved] danonbass Pro Tools 10 2 06-13-2013 12:41 PM
No audio after installing Pro Tools 10.3.2 [solved] wullie macOS 5 12-17-2012 03:42 PM
PDC Question #1 - Aux Bus Inserts - PARTIALLY SOLVED. original_min 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-04-2008 05:59 PM
Producer Factory Pro Plugin Question SOLVED Flan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-05-2008 01:16 PM
