Old 06-04-2013, 10:10 PM
zwolf zwolf is offline
Default Finished 30 day trial, purchased boxed version - question about installation
Hi there -
So I purchased an ilok a month ago to enable the 30 day trial, and I see one comes in the box as well. It seems I could just use my existing ilok with the new activation code and I'd be good to go without actually installing the software...as it is already on my drive from the trial. But I thought I'd ask first...
And if this is the way to proceed, it's been my understanding that the trial was a complete version of PT 10. Is there anything I'd be missing in terms of virtual instruments or plug ins by not using the installer discs?
Thanks - just don't want to over complicate or screw it up!
Old 06-04-2013, 10:22 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Finished 30 day trial, purchased boxed version - question about installation
Just download the permanent license to your existing iLok key and keep the brand new as a spare for future use. There is no difference. Also, there is no difference in trial software and release software, it is all the same, only difference being the time limit in the trial license.
Janne
Old 06-04-2013, 11:06 PM
guatamas guatamas is offline
As Jfreak said keep both iloks, you'll never know when the spare will come in handy
Old 06-05-2013, 05:49 AM
Thanks for the help!
Old 06-09-2013, 09:57 PM
Ok guys, feeling kind of dense, but I need some more help here.
I waited until my 30 days were fully up to register because I anticipated a few snags - was probably a good idea. Then iLok was down for the weekend...
So once back up, I went to iLok and realized that what I had in the PT box was a registration ID, not a license or activation code. So I went to Avid.com, set up an account, and went through the process to register my copy of PT. I expected to receive an ilok license code at the end of the process, but this hasn't happened. So...I'm not in. I don't even see anything under 'my products". Part of the problem seems to be that I don't have anything to download here, I have a boxed version. But I don't want to install the boxed version as I already have it on my computer from the trial as previously discussed. And as far as iLok is concerned at this point I have nothing but an expired PT 10 trial license...
As I said, I feel pretty thick and as if I'm missing something obvious. But I'm also getting desperate because I really need to be able to use this tomorrow.
Any help/insight will be greatly appreciated!!!!
Old 06-09-2013, 10:12 PM
What instructions are you following?
At the end of the process on Avid.com, Avid sends some magic in the background to iLok.com that causes a licens to be deposited in your iLok.com account. So you go to iLok.com, log into your account and sync your new license to your iLok dongle. Hopefully this will all work fine with the changes just happened at iLok.com.
You should not be trying to random walk through this, find the instructions.
Darryl
Old 06-09-2013, 10:15 PM
jeffro's Avatar
jeffro jeffro is offline
Welcome to the community zwolf!
If you bought a boxed copy of Pro Tools 10 with no Activation Card then the iLok would be pre-authorized. You can confirm this by plugging it in, then launching Pro Tools 10.
linkedin
Old 06-09-2013, 10:21 PM
Yep - just figured that out!
Thanks Jeffro and Darryl. That was a short lived problem
Purchased Boxed Version of Protools 10, registered. Don't have 10/11 bundle license Jstrat31 Pro Tools 11 4 06-24-2013 11:02 AM
Protools 10 trial to purchased license question TheBaron Pro Tools 10 3 03-20-2013 11:58 AM
Pro Tools 10 Trial to Pro Tools 10 Full Version - Installation Problem janos macOS 2 01-09-2012 07:56 PM
Question about installing TL Space Native DVD / Removing Trial Version jasonfarnham Virtual Instruments 4 07-31-2011 02:38 PM
Quick Question About Boxed Version Of PT8 (Upgrade). On Sale For $127. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-27-2008 09:13 PM
