Old 08-06-2011, 08:13 PM
cometsincaves cometsincaves is offline
Default Help setting up drum machine as MIDI slave
So I'm trying to slave my Boss DR3 drum machine to PT 9 on my mac. What I want is the drum machine to sync up with any tempo I set in pro tools and for it to stop and start when I stop and start pro tools.
I know it's possible because I had this working before, but can't remember if it was before I upgraded to PT 9 or what not (which also makes this particularly annoying of course).
I followed the instructions in the PT reference guide on MMC slaves to PT to a T. I experimented a ton with all the midi settings in all the different midi menus and transport and still cannot seem to get this to work. I feel like there's like one or two options that just need to be set right that weren't mentioned in the guide, but can't seem to figure it out. Anyone have any ideas?
Right now when I press play, it just says "waiting for sync" on the bottom bar and doesn't do anything.
Old 08-06-2011, 08:18 PM
Default Re: Help setting up drum machine as MIDI slave
Try MIDI Beat Clock. DIN MIDI Interface Out to DIN MIDI In on Boss DR3. Enable this connection in MBC Option.
Aaron Mulqueen - 001 HD Native
Old 08-06-2011, 08:22 PM
Hi Aaron, thanks yeah I had that on. Ok right after I posted I did something, not exactly sure what when I was fiddling and got them to start talking. The DR3 starts and stops with PT now, but it won't sync to the tempo I choose in Pro Tools. I'm not supposed to use the conductor track in the transport right?
Anyone know how, if I'm this far and the tempos won't sync, where I go to fix that?
Old 08-06-2011, 08:27 PM
Is the Boss DR3 Clock Source set to External?
Old 08-06-2011, 08:31 PM
Aaron dude are you like psychic or something that's hilarious. Like 5 seconds before I checked your post I went and switched that setting on the Boss, I had set it earlier to "remote" which detects some things but not others, or something like that, earlier when I was trying to get it to work. As soon as I switched it back to Auto, (it doesn't have ext. per say), IT WORKED!!
Alright problem solved, thanks for your help!
Adam
midi machine control (slave) missing from peripheral setup GStyle Pro Tools M-Powered (Mac) 0 04-12-2008 10:44 AM
Slave Protools M-Power to older midi drum device jazzyeric MIDI 0 03-29-2006 09:03 PM
trying to slave my drum machine to my 002? skyking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-29-2003 02:18 PM
Help with setting up Drum Machine jpoprock MIDI 4 08-02-2002 01:40 AM
Is it possible to make PT a slave to another MIDI device (such as a Roland VS machine Mikchek MIDI 7 03-02-2002 10:38 AM
