Mix Cards in a 9600 running Ex Post Facto
Hello all,
I have a hypothetical situation to lay on you, which will not be so hypothetical if I get the answer I'm looking for.... I have a 9600/233. To run a Mix set up using PT 6.4.1 on it, I reckon that I would have to put a CPU upgrade in (e.g. the G3 1Gig by PowerLogix) and run Ex Post Facto. If this is true: When I look at plugs that are compatible with Mix, many companies specify a computer running say, a G4 at 700, etc. I thought the whole point of the TDM architecture was to make the DSP INDEPEDENT of cpu strength. Am I missing something? Mark
"I don't want to gain immortality through my work. I want to gain immortality by not dying." Woody Allen |
Re: Mix Cards in a 9600 running Ex Post Facto
Well, just to give you hope, I got LE 6.2.3 running in panther xpostfacto in a 233 g3 beige with audiomedia card. And plugs such as t-rack worked. I didnt even bother to check if this was a supported configuration, but I think it is far from supported. I dont own pt 6 so I just tested it from a friends cd because I was curious. I suppose you would better version 5 in os9. Why do you want 6? I suppose plug ins...
But to me it seems that if you have the right os, thats all the installer cares about. Good luck Pepo |
FWIW, I have a Mix system on a 9600 running PT5.1. I have a G3/400 card in it and can boot to OSX with XPostFacto. I run PT 6.4 just to get the 'feel' of it as I don't have a newer mac. I can do 2 track edits. You can feasibly do small track count sessions. But anything over 8 tracks and my 9600 can't keep up and you get PCI bus error messages and the like. BUT it can be done, it can run smooth but slow for 2 track.
byron |
HELP!!! running 2 core cards on mix sys & lights on cards??? HELP!!! | A Spooner | Tips & Tricks | 6 | 07-08-2009 06:55 PM |
9600 G3 cards, who's using what? | Redbeard | Pro Tools TDM Systems (Mac) | 8 | 07-01-2001 07:31 PM |
9600/ G3/300 and UW cards? | cander | Storage Subsystems | 1 | 09-22-2000 11:31 AM |
9600/ G3/300 and UW cards? | cander | Pro Tools TDM Systems (Mac) | 2 | 09-22-2000 10:07 AM |
G4 450 newertech cards/ 9600 | bigtree | Pro Tools TDM Systems (Mac) | 0 | 08-14-2000 05:13 PM |
