Which kinda video to route through FireWire?
Guys,
PT imports QuickTime videos and Avid linked OMF's as I understand. I recently worked on Avid/PT workstation with Avid Mojo, and PT only playbacks OMF's to external monitor (through Mojo, FireWire). It shows special controls on video track, whether I want a composite or component output and also PT shows the file's videosystem (PAL in my case). But if I import Avid DV .mov (or any other kind of DV .mov) it playbacks it only in QT Movie Window, there's no possibility to route the video through FireWire port. Could you please tell me the place where I can read which kind of videofiles are fully supported by Pro Tools (6x + 7.0)? Or it must come as linked OMF to see it on external monitor? |
Re: Which kinda video to route through FireWire?
Options -> Quicktime DV out Firewire (for PT7, it was elsewhere in PT6)
You movies need to be in DV format, but that's about the only requirement. Motion JPEG etc. won't work. |
Thanks, I finally found that in Reference Guide. Just wonder why I didn't find it in previous searches It must be Apple (QuickTime) DV, Avid DV won't.
Hmmmm....DV is just that, DV...there is nothing special about QT DV. Apple doesn't apply any voodoo to it...Wonder what's up with Avid or the settings?
It's such a fine line between stupid, and clever. -David St. Hubbins |
It's written in the manual, Avid DV files won't play through firewire. And I don't think DV is just DV because of these different codecs (Avid DV, Microsoft DV, Apple DV, ya know) available.
Best route for firewire? Via Laptop setup | jabr | Pro Tools 9 | 2 | 07-30-2012 05:58 AM |
Can I use M-Audio Firewire 410 to simply route 11R to my Rokits? | Fezzler | Eleven Rack | 10 | 12-23-2011 01:14 PM |
using PT to route video and midi | foxforceFIVE | Pro Tools TDM Systems (Mac) | 0 | 03-01-2008 02:31 PM |
It's kinda sad that... | Tito Ricci Arballo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-14-2004 01:00 AM |
How do you route video to DV port via Premiere using a Formac box? | ragbor | Pro Tools TDM Systems (Mac) | 1 | 10-04-2002 10:49 AM |
