Long Pause When I Hit Record/How Do I Fix????
i am using a mix3 with a mac quick silver 944mhz ....5.1.3 protools version.....when i record 11 drum tracks at once the little hand starts grabbing for a very long time,over 15 seconds before it goes into record.....even when i am recording one track ...there is a pause for a few seconds....what can i do to fix this????
Re: Long Pause When I Hit Record/How Do I Fix????
Preferences, 'Record allocation' is likely set to 'Use All available Space' instead of specifying 10 minutes, or something reasonable...
That'll get you rolling much quicker. Cheers |
In your prefs.. change the Open Ended Record Allocation to a value like 10 minutes.
Rail
On that vesion of PT, Mute Frees Voice makes the record delay longer. Turn it off and see if that helps.
www.barnabas.com Barnabas MultiMedia |
You havent got the 2 bars checked in the transport window have you?
That has had me before as I am using a c24 and didnt have the transport window showing on the screen.
A Gentleman is one who can play the bagpipes, yet chooses not to. |
beside setting the allocate size as others said, you could also make a selection and then press record.
Optimize your HD. That won't solve the problem for long though. OSX has this problem solved. |
Long pause after clicking record | docbop | Pro Tools TDM Systems (Mac) | 15 | 06-28-2011 06:13 PM |
Long Pause after stop on HD1, how to fix? | Cowgs | Tips & Tricks | 3 | 03-09-2007 06:47 AM |
long pause before audio starts | Scanners | Pro Tools TDM Systems (Mac) | 2 | 07-14-2006 06:09 AM |
long pause before 002r will record | 16yearsjeff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 02-23-2005 09:07 AM |
Long pause before recording | APAULOS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 12-18-2001 01:33 PM |
