Dx compression implementation? Threshold automation or set'n'forget?
Hi guys,
Share your thoughts? My system atm is I'll have a compressor on each dx track (~10ms att and 95 rel) and automate the threshold for each clip so it's 2-3dB reduction at peaks, but this is quite time consuming. I've considered one compressor on the dx bus instead, easier to automate one threshold for all the dialogue to hand, but this means any change to VCA & track faders would change the gain reduction every time? I've also seen people set and forget a compressor across the bus and not open it once, How pedantic do you guys get with your comp levels? automate threshold for each clip or (assuming the dx clips are approx the same level) leave it alone on the track with an eye on the gr meter? |
Re: Dx compression implementation? Threshold automation or set'n'forget?
I have one comp on the dialogue buss. Which I set for 2/3 dB peak taming. I only automate it when I hear it working too much. I don't like comp on the channel
Yeah I'll level my audio with faders but a lot of dial sounds too peaky to me so I'll use compression for the tone, ah Waverider looks similar to the waves vox rider have you compared them?
That's sounds like what I'm considering switching to for sake of workflow, have you ever had a problem with simultaneous dialogue lines? I would have thought individually compd dx could be more intelligible/less masked?
That's my workflow too, one comp on the dialogue bus, just tickling the peaks and ride into it when necessary.
Eq on the individual dialogue tracks and clip gain for level control clip to clip. Sometimes individual compression on tracks as well in difficult scenes with high backgrounds, clubs, parties etc. I don't like the sound of too much compression or de-essing myself, but peoples tastes vary. Depends whether its film or TV too, TV usually needs a firmer hand. Which comp or multiband to use though, is a whole other issue and much discussed elsewhere.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12 |
Yeah, Waves actually is the copy. It's not as good as it records its own automation where Waverider actually writes volume automation (it acts as a HUI controller). Much prefer Waveriders controls too.
First off thanks for your replies guys, I've read posts from each of you before on other threads and they're always good.
Do you have a problem when 2 lines of different level overlap? (someone starts yelling over whispering) Wait individual comp with high noise production dialogue? Why isn't that when is would be best to share gain reduction over the bus? |
Yeah I'm considering two Dx chains with compression (using the alt whenever there's overlapping lines with different levels), bussed with sends for easier switching automation and a VCA controlling the two as master Dx Level |
Maxim Link Threshold/Ceiling Automation not remembering (please replicate) | joachim | Pro Tools 11 | 11 | 09-11-2015 11:57 AM |
Volume Automation vs. Compression | AndyJCP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 08-17-2009 11:49 AM |
Link Volume with Threshold automation | Nathan W. | Post - Surround - Video | 6 | 03-10-2008 11:27 AM |
Compression threshold level? | porkipine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-11-2006 02:13 PM |
plug-in automation bug/L1 threshold | flieschut | Pro Tools TDM Systems (Mac) | 0 | 10-27-2003 05:05 PM |
