PT8 pointer bug
Have any of you guys noticed that when you click on a drop down menu in PT8 that hovers either over a region,insert(edit view),etc that your pointer turns into your edit tool as if the menu is not even there.
Example: Go to regions list,click and try to select "select" then "unused".If the drop down menu is over a region then you can't freakin use it because your mouse pointer changes to your specific tool to edit the region that is under the drop down menu. Another: Every damn time I try to click on my tracks name to duplicate the track my mouse goes thru the drop down menu onto the track inserts and opens whatever insert was under the "Duplicate" command. Digi you gotta be kidding me that this [bleep][bleep][bleep][bleep][bleep] got thru beta testing!!!If so you guys need to actually get real beta testers and freakin pay them! Digi please chime in on this.
Bug ridden Pro Tools 8 but back to 7.4 HD2,192 I/O,96 I/O,Midi I/O,Control 24 |
Re: PT8 pointer bug
People test this for christ's sake!Nobody else on Windows XP have this problem??????
Re: PT8 pointer bug
Yes I see this on XP Pro LE as a GUI issue but it's functionality is fine, no?
filosofem |
Re: PT8 pointer bug
Weird problem, but I couldn't reproduce this on PT 8 (no cs update) LE on XP.
Could anyone reproduce this on a different machine? Best of luck to you sorting this one out. ***EDIT*** I take back everything I said. For some reason I can repro it now, but not earlier. This is pretty strange and this isn't the only weird thing I've seen with the menus. Digi needs to take a look at this. -Justin -Justin
Justin Walker |
Re: PT8 pointer bug
What really sucks is I love the new GUI,I love the theory of all the new features(when they work)and I want for the life of me to be able to use it in my studio.DB-33 can't even be found 50% of the time I open a session...................I need to re-boot then it's there.My main concern over everything is the non-stop out of CPU errors when I try to record.It made me look like an ass in front of 2 seperate clients recently and lost me money.I load 7.4 and everything works like it should.I still can not record in 8.
Re: PT8 pointer bug
This was one that was logged awhile ago for a fix, but I'm not sure when it may be implemented.
Re: PT8 pointer bug
Nust be just Le as i am HD and dont have that bug.
Re: PT8 pointer bug
I'm HD2.
Re: PT8 pointer bug
Wow i cant reproduce that here
Ill try again |
Re: PT8 pointer bug
It's really strange.............sometimes it does it and other times it works fine.
Another bug I just found was I am losing my mouse scrolling in both the edit/mix windows in the middle of sessions.A PT re-boot cures the problem.There are so,so,so many small bugs in 8 and it might take a bit to find them but you will.
Need pointer, avid mc-Aaf | ErikGuldager | Post - Surround - Video | 3 | 01-26-2012 08:29 AM |
8.0.3 jumpy mouse pointer | A Chapman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 04-22-2010 01:28 PM |
Big Mouse Pointer | Delta Music Belgium | Pro Tools TDM Systems (Mac) | 5 | 09-20-2006 12:08 PM |
June Pointer R.I.P. | BAJ | General Discussion | 0 | 04-23-2006 07:55 PM |
pointer size | mixer | Pro Tools TDM Systems (Mac) | 2 | 09-11-2002 12:32 AM |
