#231
Re: PT8 CPU Usage
He doesn't get it. Nevermind.
-------------------------------------------------- Why do people keep running over a string a dozen times with their vacuum cleaner, then reach down, pick it up, examine it, then put it down to give the vacuum one more chance? |
#232
Re: PT8 CPU Usage
I am so sorry I offended you with my reply .
Yes, I get it, but I need more time for testing VI's/PT8 behavior, either in Win XP or in Win 7. Unfortunately, I do not use Pro Tools all the time, as I used to. I work every day (long days and nights ) as an AV Production Systems engineer for big corporate shows all over the US and it is really very time consuming. I will post some test results, from my perspective, ASAP. Sorry for the confusion. |
#233
Re: PT8 CPU Usage
None taken! It's all good
#234
Re: PT8 CPU Usage
The "other issue fixes" must be b****y serious to delay a fix that would / might cure the unusability of the whole software package for, apparently, many users. What else is so bad? Was there any serious testing before release that such "issues" got through? As to the last point, that "you don't call the shots".... as you seem to be the contact with the whole of the User Conference, that statement doesn't tell us many good things about the relevance of the customers to Digidesign. You can tell I am getting very "cross" |
#235
Re: PT8 CPU Usage
#236
Re: PT8 CPU Usage
Cheers,
#237
Re: PT8 CPU Usage
DIGI, thanks for the reply. However, the powers that be must have some idea when it might be released. I know telling everyone that something will be released on a certain date, and then if it is not, can be problematic. However are we looking at weeks, months, years... Some idea would be appreciated.
Thanks again, Darren |
#238
Re: PT8 CPU Usage
I'm doing all I can to press for a faster fix, believe me. |
#239
Re: PT8 CPU Usage
Hi have the same freeze problem with my new iMac
2.93 Ghz Intel Core Duo+4 GB Ram! With two or more VSTs open the computer freezes... Think about this: until one month ago I was a happy Cubase 4 LE user on my rotten 2001 windows xp2 average pc... but yet I could use 8 to 10 vst use plus reverbs, delays... no freezing! I decided to switch to protools/mbox, I have a powerful computer and it freezes with 2 vsts open?!? |
#240
Re: PT8 CPU Usage
If you minimize Edit/Mix windows make any diference? How much CPU usage? |
What would normal disk usage considered to be in the usage window? | Digitopian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-08-2009 09:50 PM |
Help understanding CPU Usage, RAM, Disk Usage... | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 02-03-2006 07:41 PM |
HTDM not showing CPU usage in the system usage | Brandonx1 | Pro Tools TDM Systems (Win) | 3 | 12-19-2004 09:45 AM |
CPU usage | Room24Prod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-16-2004 06:20 PM |
DSP Usage? | Smithtrax | Pro Tools TDM Systems (Mac) | 1 | 10-15-2003 02:13 PM |
