Neve 88D and Pro Tools
First off, I'm using an 88R Neve console with a HD Accel 3 system, and when I sync up the time code the Neve follows pro Tools fine except in loop playback. The time code on the Neve doesn't reset when looping, is it something I'm doing wrong or that somebody else knows of? Just using the PT sync I/O.... i think.
I got an email this morning from mix magazine stating that Neve was releasing their digital version of the 88R console called the 88D. Here's the link to that article (http://mixonline.com/neve-88d-aes2005/). Anybody know anything about it's compatibility with PT? The article says it's ready to go for PT and Nuendo but it just seems weird that all of the sudden Neve is bridging that gap and actually working with someone else..... Oh yeah, and I really suck at spelling.... is there some way to spell check on these forum boards? ~Radio |
Re: Neve 88D and Pro Tools
Hmm.. to the best of my knowledge, you may wish to use an external clock to sync the board and your PT systems together on the same timecode. I have not set up a rig of that calliber honestly, but have seen a lot of folks set them up that way. You may wish to post in the HD section also to see what a few fellow HD folks have to say. Goodluck on your setup!
Sradio,
Not knowing the automation package you are using, I can only suggest to look up the setup pages..make sure it is running in continuous sync mode. Some TC readers acquire lock, then switch to freewheel. Also it may sound obvious, your source code shouldn't run over the 23:59:59:00 address. Are there TC output options in the sync I/O ? You should check that also. I'd call Neve support with this one. good luck,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Most devices only look at the SMPTE numbers initially for location... then phase lock to the SMPTE synch words... so they don't know that the incoming LTC is looping.
Rail
Yes.."phase lock" is what I meant (thanx Rail)
Another workaround would worth trying is; Print the LTC on an audio track, should be accurate enough for automation if no picture is involved. Then, temporarily mute a chunk of the TC track at the top of your loop. IMO the Neve will/should re-acquire positional lock. At least this is the way I work with an Optifile Tetra. I don't have the sync IO. good luck,
Check your email,
cheers
Transferring sessions between Pro Tools and AMS Neve | noiseboy55 | Post - Surround - Video | 18 | 02-16-2010 05:32 AM |
AMS-Neve CineFile dubber with PRO TOOLS? | ProToolsguy56 | Post - Surround - Video | 1 | 09-08-2005 09:54 AM |
NEW Neve vs. OLD Neve | Soliton | General Discussion | 3 | 03-16-2005 09:57 AM |
WHICH NEVE?!!??!? | AEXXL | Tips & Tricks | 22 | 05-22-2003 10:23 PM |
pro tools and neve v | ivet | General Discussion | 1 | 07-07-2001 07:35 AM |
