Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 11-09-2009, 05:27 AM
redcoat redcoat is offline
Default All running but no input from instrument
Hi all
Brand new to this so it's all learning for me. I have the software installed on my (Vista) machine, and the Fast Track connected. It all works, in that the software runs, loads sessions, plays back etc, & the PC recognises the interface and playback from 'Essential' is via the Fast Track outputs (eg to headphones). The only probelm I seem to have is that when a guitar is plugged into the interface it's signal does seem to reach the 'Essential' software - I know there is a signal becasue I get a good 'direct monitor' output back to headphones if selected, but it doesn't seem to go any further. As far as I can see everything is as it should be, but no instrument input (I don't have a mic to try out) to the software.
What am I doing wrong?
Thanks in advance.
Old 11-09-2009, 07:53 AM
Jared Jared is offline
Default Re: All running but no input from instrument
The Guitar Input on the Fast Track is In 2. The track in Pro Tools defaults to input 1. From the mixer window, go to the I/O section and click to change the input for your mono audio track to be interface>In 2 (Mono).
Old 11-11-2009, 01:22 AM
Many thanks for that - I'll give it a try.
Old 04-17-2010, 09:00 AM
ecaranci ecaranci is offline
I've got the exact same issue. I tired the above and still nothing. Sounds great in the direct monitor headphones but no input in essentials.
Instrument Input greyed out lexaudio macOS 2 10-22-2013 04:17 AM
virtual instrument input problem thruhiker Windows 1 02-02-2013 07:42 PM
2 instrument tracks each controlled by different MIDI input/instrument Midimax Pro Tools M-Powered (Win) 0 03-20-2012 03:10 PM
Audio won't record through instrument input CoreyMaim Pro Tools SE and Essential (Mac) 3 03-04-2011 10:56 AM
Need help with running two Instrument(midi) tracks with the same plugin... Kat5guy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-19-2009 09:11 AM
