5.3.1. compatibility problems with Quicktime codec
Does anyone know or are there are listings of what codecs can and cant be handled by pro tools?
I use PT 5.3.1 on the PC and use Quicktime movies through Quicktime 6, are there any problems between these? 5.3.1 is quite old compared to Quicktime Player 6....should I upgrade pro tools (any recommendations?) or should I downgrade Quicktime to smooth out any problmes Any thoughts greatly appreciated....actually you'd be saving my life! |
Re: 5.3.1. compatibility problems with Quicktime c
Since Pro Tools uses the Quicktime engine, any codec that is supported by Quicktime will work in Pro Tools.
Re: 5.3.1. compatibility problems with Quicktime codec
Here's a pretty complete list of what different versions of QuickTime support
hi glenbo
i'm also working on PT 5.1.3. the big problem we had were "muxed" quicktime files. in these files audio and video were rendered in the same data information. so we had problems to BTmovie or "import audio from current movie". use the cleaner to rerender those files. maybee this helps. cheers |
Thanks for that....
What your saying sounds about right, I've been through all the quicktime compatibility issues and compared codecs etc for quicktimes that have been working fine and those that have been bad and the only thing that seems to stick out IS the ones that had imported audio from it... I'm still gonna upgrade PT, seems about time really. Been using 5.3.1 since late 2002.... Cheers |
Quicktime AAC Codec Crashing PT 8.0.1 | jackmackdaddy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-09-2010 12:46 PM |
quicktime codec from finalcut | tsd | Post - Surround - Video | 9 | 09-02-2008 12:25 PM |
Best Codec for Quicktime Movies? | Starcrash | Post - Surround - Video | 9 | 09-25-2005 06:21 PM |
Quicktime codec | ctgsteve | Pro Tools TDM Systems (Win) | 0 | 07-04-2003 12:30 AM |
Quicktime Codec | whirlwind | Pro Tools TDM Systems (Mac) | 7 | 05-01-2003 03:34 PM |
