End of Region noise/click Issue takes new form!
Hi
Well I finally got used to recording with ADC turned OFF to avoid the spikes introduced into my regions at the end of every take. However, now I am getting something similiar with ADC OFF, but AVAILABLE in the Playback Engine. I am getting weird bursts, pops, noise, etc, at the end of all my regions as soon as i stop recording. when I zoom in to look at it, it looks correlated to what I was recording. Its not the sharp "digital click" kind of thing that happens with ADC ON. Its looks like actual audio. As if a a quick section of sound (about 10ms or so) is being added to the end of my regions. (Kind of what it would look like if the singer was trying to speak at the instant i terminate recording) Its too quick to guess what it is, but it looks pretty much the same on every track. And when I play back a bunch of tracks with all sorts of overlapping, staggered regions, I hear a symphony of clicks as the play head passes over them. This is really getting frustrating. I dealt with the ADC issue, but now Im getting it with it OFF. Is anyone having similar experience? I have to manually chop the end of each region recorded to get rid of them. Its quite annoying. I wish I could post pics here to show the visual of it. Its definitely not a clock issue (I can see the audio being added, and its not random), I have tried all the standard troubleshooting. And I am still using PT 6.7cs8, HD3 accel, OSX 10.3.8. Any ideas? MT P.S. Can anyone tell me if 6.9 still has the End of Region clicks/spikes with ADC ON problem?
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8 PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626 •••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!• |
Re: End of Region noise/click Issue takes new form!
Are you running low on DSP? I have some friends who have had occasional pops and clicks when they record at the edge of their DSP.
Mixing in the box, requires thinking outside the box. My New Instructional Mixing DVD 2 is Shipping www.tonysound.com http://twitter.com/tonysound |
Hey Tony,
Thanks for the suggestion but my issues occur while tracking, using very minimal, if any, DSP/plugins. Im surprised that no one else is chiming in with the same issues.. Maybe I got a bad RAM stick or somethin.. But this is getting out of control. Im almost certain that it is related to ADC being enabled in the Playback Engine, regardless of it being used or not.. ?? MT
Couple of suggestions: Change the "Delay compensation engine" to NONE in the PB engine, and Turn on "Auto fades". Let me know if this helps. -tv
Tim vdB Avid Audio "There's a fine line between stupid and clever." |
Digi, do you have ANY info whatsoever about the ADC/End of Region clicks problem? I feel that this is one of the most overlooked, but incredibly significant issues with Protools. Makes for very unprofessional recording sessions when everyone around me is asking why there are clicks in my recordings and their headphones, and I have to shrug it off as "eh, its just a PT bug". Have you guys been able to reproduce ANY of the ADC click issues discussed in this forum? thanks MT
MtEverest:
You are not alone in your click/noise problem and I am using 6.9. I can't figure it out, but it just started happening today. Exactly as you described. Anyone else with any ideas as to how to rid ourselves of this problem? I'd prefer not to have a workaround such as auto fades. Digi? |
Sorry for bumping up an old thread.
I'm not using HD (and I'm on Windows), but I have the same issue. Using PT 10 with Mbox Pro, and I get exactly the same "pop" at the end of each audio region I record. Is there a fix for this? Thanx. |
Setting the Delay Compensation Engine to "Short" SOLVED my problem.
I have the same issue with my Mbox Pro and PT10.2 and turning on my delay compensation to short also got rid of the issue. I also have run into a delayed punch in when using quickpunch, when I punch in I don't here the new input signal until half a second later, very odd, followed by a snap at the end of the file. I have deleted data bases etc still not sure what causes it. There is another newer thread about this except the guy who started the thread was getting really loud sounds " explosions" at the end of his recorded files.
http://duc.avid.com/showthread.php?p...30#post1963430 |
Has this been addressed, Avid?
“Separate Region” Operates On All Related Takes - where I am wrong? | sjs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-28-2009 11:23 PM |
Seperate Region Command PT8 takes minutes...! | m4tune | Pro Tools TDM Systems (Mac) | 12 | 01-02-2009 08:23 AM |
Can't Ctrl-Click to view alternate takes with smart tool? | spaids | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-28-2008 09:36 AM |
Elastic Audio, X Form on complete vocal region/track - Help | Mike Emerson | Tips & Tricks | 6 | 07-25-2008 10:16 PM |
After Loop record-selecting different takes from Region list | Shanegrla | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-10-2008 11:12 PM |
