MTRX Studio automatic sample rate switching issue
So as I move between sessions of different sample rates, protools crashes if I have the 'Conf' - 'Sync' - 'Sampling' set to adapt to Digilink 1. If I set adapt to internal and change manually I can avoid the crashing. I am on the current dadman (5.6.3.8) PT 2022.7 / Catalina 10.15.7. It was doing this on previous versions also. But seems like end of lat year it was adapting to Digilink just fine. However my MTRX Studio is in a semi broken state - no front panel lights, Device list showing front panel status as 'error' I have been meaning to send it in, but I can be without it fora two week or more period. ug.
Thoughts on the adapt setting crash? Is tis reproducible? I have many clients still using 44.1 and money on 48 so its a constant issue manually switching.
http://www.ainsliegrosser.com/ MacBook Pro 2019 64GB OSX 10.15.7, HDX, Sonnet Chassis, PT Ultimate 2022.9, S3, Dock, MTRX Studio |
Re: MTRX Studio automatic sample rate switching issue
Disable the Avid Audio Server, if you haven't already (and you have to do it after every new HDX card driver install since that repairs it.)
Go to Applications > Avid > AvidAudioServer Fine the "AvidAudioServer" application in that folder Change its name to "#AvidAudioServer" You'll be prompted for a password. Restart computer (what happens is the auto launcher can't find the changed name application so it doesn't launch) One note is Avid HDX will no longer appear in Audio MIDI Settings after this change as a sound output option. (But most people using a MTRX don't need that anyway -- if they need system sounds, DVS/Dante can be used)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
DAPS won't see the MTRX if you do this
[email protected] Newcomer Audio Post MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... |
I would try using DVS for this if you haven't already. It interfaces in pretty much the same way, except it has about 1/4 of the latency and 1/90 of the cost of a HDX card running under Avid's coreaudio drivers. If you don't need more than 64 inputs into DAPS, you could even keep using your HDX hardware in Pro Tools this way...
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
Dolby Audio Bridge always seems to come in the slowest in loopback and video sync tests here. It is always the configuration with results that are furthest away from a standard HDN setup using only Pro Tools.
MTRX and session sample rate and slaved clocking | bluemoa | Pro Tools | MTRX & MTRX Studio | 1 | 08-02-2022 11:58 AM |
DADman/MTRX Studio sample rate, Avid Control monitoring issues | raw | Pro Tools | MTRX & MTRX Studio | 8 | 01-24-2022 08:09 PM |
DADMAN + MOM + MTRX Studio = phase switching? | Jeff Schmidt | Pro Tools | MTRX & MTRX Studio | 3 | 08-27-2021 04:31 PM |
DVS Sample Rate Switching | ViciousLullabyz | Pro Tools HDX & HD Native Systems (Mac) | 2 | 09-14-2020 11:08 AM |
888/24 sample rate switching | dekype | Pro Tools TDM Systems (Mac) | 1 | 01-21-2000 07:05 AM |
