Old 02-02-2024, 03:53 AM
Rockman413 Rockman413 is offline
Default Why the audio track can't be rec armed?
Hi there,
For some reason, one audio track I can't record arm it, although I can enable monitor "I" , I checked it has a valid input and output, and even if I create another audio track with same I/O I can record enable....
Wondering what may cause this? The record arm button is still dark red but slightly darker.
Mac Pro 3.0G 8 Cores PT HD use with Ensemble Thunderbolt
Old 02-02-2024, 05:07 AM
uptheoctave uptheoctave is online now
Default Re: Why the audio track can't be rec armed?
A screenshot of the mix window will probably help here.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Old 02-02-2024, 05:18 AM
Farhoof's Avatar
Farhoof Farhoof is offline
"Record safe" might be enabled by mistake. Command+click on the record button, see if that helps, it should change tone a bit.
6 second lag when audio track is armed to record... kennyc63 Pro Tools 2019 7 02-12-2020 12:50 PM
Track peaks when armed... patswope 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-06-2010 07:13 AM
Can't monitor track while armed? f69tele 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-14-2010 12:00 AM
Protools 8 not playing audio when track is armed. broken81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-14-2009 03:48 PM
delay when track is armed steve_srt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-22-2008 11:46 AM
